Is there a project fitting my requirements ?
Discussion in 'CNC Mills/Routers' started by lalebarde, Jul 24, 2018.
  1. lalebarde
    lalebarde New
    Hi,
    I am new to CNC and to OpenBuilds. I have reviewed many projects trying to fit my needs. At this point, I have tagged :
    But this is still far from my requirements. Here are they :
    • Vertical Y axe
    • Huge : 1.5m Y axe and 3m X axe (working area)
    • > 4kW milling to use wood shaper tooling
    • Rack & Pinion for X and Y axes
    • lathe or 5x option included
    • Cheap dust chamber (tarp or tarpaulin or frame or cover) with a plug for suction
    • Opensource file formats (dwg, dxf) for use with opensource or cheap CAD software (QCAD, OpenSCAD, ImplicitSCAD)
    Do you know please the closest project to my needs ?
    CNCrouterparts has an system that is about as close as you're going to get to your specifications. I don't know if it'll take a 4kW spindle though.
  3. lalebarde
    lalebarde New
    Thanks Rick. They propose a 2.2kW spindle. I am going to ask them for 4kW.
