OpenBuilds CONTROL Software
  1. dJOS_500
    dJOS_500 Journeyman
    They should be 133.333 according to that.
    TBH, that seems a bit low, but I’m guessing your machine uses belts and has a reduction pulley setup.
    If you had lead screws, I’d expect to see around the 200 mark.
  2. Goldenhouse
    It is a screw drive and I tried it both ways 133.333 and 133333.00. I'll try 400 and see if that stops it from freezing up now.
  3. Goldenhouse
    Setting them at
    Setting them at 200 unlocked them. I'll finish my setup and then calculate the what they should be set at.
    thanks for the help
    dJOS_500 likes this.
  4. dJOS_500
    dJOS_500 Journeyman
    Good stuff!
    For reference, I have a ballscrew on my z axis and that runs at 400. Anyway, at least you are moving now and that should let you calibrate the actual movement.
  5. David the swarfer
    do not plug in the Interface AND the USB from the PC at the same time. one or the other, since the Interface is desgiend and intended to replace a PC.
    However, I would use the PC for the initial setup and then use the Interface to run the machine, PC is just much easier for setup.
  6. GS76
    GS76 Well-Known
    To whom it may concern:
    Is there a Beta version of the OpenBuilds Control software that I could test?
    I enjoy testing software.
    Regards,
  7. Vinion
    Vinion New
    Is that other app still running on your PC? It comes up right after the API call in the log, so if its still running you were talking to it, not CONTROLs backend (they might be listening on the same ports as us)
  9. Vinion
    Vinion New
    No, the other app is not running on my pc...
    Do you use the SourceRabbit code on Openbuilds control ?
    No, and you are quite welcome to verify that for yourself : github.com/OpenBuilds/OpenBuilds-CONTROL
  11. David the swarfer
    in the background of that error message the GRBL version is displayed as
    V1.3a Rabbit GRBL for the ESP32
    I am pretty sure the since CONTROL is designed and tested to work with GRBL 1.1 on an Uno and grblHAL on an ESP32 that is will not be happy to talk to Rabbit GRBL, whatever thai s.
  12. Peter Van Der Walt
    If he has the firmware, he likely had their software too. That message can't (likely) come from Firmware, so I am still betting on a API process running in background. Per the log just as he sent the job to the backend (thats an http post) the error popped up, so we were probably talking to Rabbit's server running in background during the http post, not the CONTROL/Electron/Express backend
  13. Peter Van Der Walt
    OpenBuilds CONTROL V1.0.371 should be released shortly (some time this week)
    Changelog:
    v1.0.371: (Unreleased):
    - Fixed Issue #257 Changed Arc drawing behavior for G2 full circles in 3D viewer
    - Fixed Issue #285 Updated ACRO with Pen servo default Grbl profile PWM parameters
    - Fixed Issue #299 Change of settings numbering for grblHAL Station parameters
    - Fixed Issue #308 Improvement: Remember last used COM port
    - Fixed Issue #313 Reworded recovery wizard menu item
    - Fixed Issue #316 UI enhancements
    - Fixed Issue #321 Switched Windows CodeSigning to new EAL4+ / FIPS140-2 compliant workflow
    - Fixed Issue #322 Switched to new Notarizing workflow for MacOS per Apple Technote TN3147
    - Fixed Issue #323 Merged fix for Macro Sorting issue
    - Fixed Issue #325 Added "ok" event for Macros
    - Fixed Issue #327 Show correct fields in Steps per mm Calculator Utility in default state
    - Fixed Issue #328 Improved Flashing Wizard and added warning to backup
    - Fixed Issue #330 Experimental $40=1 in Machine Profiles to see if that resolves Soft Limits issue
    - Fixed Issue #332 Merged fix for Center Probing Offset calculation bug
    - Fixed Issue #336 Merged fix to make Framing pass optional in Surfacing Wizard
    - Fixed Issue #343 Fixed SiLabs USB descriptor
    - Fixed Issue #344 Added Reset prompt to end of Calibration routine
    - Fixed Issue #345 Merged fix for Update Grbl Settings for if settings are changed from macro/terminal/etc
    - Fixed Issue #346 Updated included grblHAL firmware binaries to v20240402 from 20230501
    - Fixed Issue #348 Merged fix for Dark Mode CSS Improvement
    - Fixed Issue #350 Updated local SSL certificates
    - Removed BlackBox X32 advertisement from Splash Screen
    - Changed DROs to use 3 decimal places per grblHAL standards
    - Updated Grbl Settings Descriptions for newer firmware builds
    - Reworded 'firmware not found' error messages to clarify
    - Updated Readme screenshot on Github
    - Updated Firmware Found log strings to show platform and date
    - Added LEAD 1010 Plasma Add-On Machine Profile
    - Fixed bug related to "$$=" commands in Serial Terminal causing issues with Grbl Settings tab
    - Updated Build environment to Node 20
    - Removed IA32 target support for Windows. Building as X64 only
    - Removed broken avrgirl dependency - temporarily removed ability to flash atmega based controllers. Will rewrite with more modern alternative soon
  14. GS76
    GS76 Well-Known
    Hi Peter,
    Could I get access to the BETA version in the meantime, or is the release date soon?
    Thank you.
    Regards
    Gary
  15. Peter Van Der Walt
  16. GS76
    GS76 Well-Known
    Thank you, Peter,
    I will see find.
    Thank you regards,
    Gafry
  17. sergiomajluf
    sergiomajluf Well-Known
    Awesome, looking forward to it, especially to see how fix #308 behaves under Linux. Also, have the team or you had the chance to check if the "remember previously used folder" features is still broken un der linux?
    cheers
  18. GS76
    GS76 Well-Known
  19. Peter Van Der Walt
    Suspected it wouldn't be visible. Sorry
    Please wait for release, still couple final build bugs to resolve
  20. Peter Van Der Walt
    We have not, no
    sergiomajluf likes this.
  21. GS76
    GS76 Well-Known
    Understood, Peter,
    All the best with the new release.
  22. Peter Van Der Walt
    Here you go :)
    Release v1.0.371 · OpenBuilds/OpenBuilds-CONTROL - also available on OpenBuilds Software: OpenBuilds CONTROL and OpenBuilds CAM and older versions will self-update as usual
    Changelog
  23. GS76
    GS76 Well-Known
    Wow! You certainly deliver when you say so. Thank you again for the great software.
  24. Peter Van Der Walt
  25. GS76
    GS76 Well-Known
    Please ignore my previous message...
    I was stupid, the X32 BlackBox was not powered up. My bad...
    All working fine now.
    Apologies for the previous message, which is why I deleted it.
    dJOS_500 and Peter Van Der Walt like this.
  26. kaoscreations
    Hi, I hope to write in the designated section. I am very happy to use OpenBuilds Control for my CNC powered by BlackBox. However, I would like to modify the postprocessor (Aspire) to indicate in the first lines of code which cutters I should use. I tried to follow the steps indicated in the guide but then Controller gives me an error (it can't read the GRBL code). Can you help me?
    The error is error 2 numeric value format is not valid or missing (Toolpname fresa a candela)
    This is the comment in .pp
    + Block definitions for toolpath output
    + Commands output at the start of the file
    begin HEADER
    "(Toolname [TOOLNAME])"
    "(Toolname [TOOL_NOTES])"
    "(Material Setup)"
    "(X Min = [XMIN] Y Min = [YMIN] Z Min = [ZMIN])"
    "(X Max = [XMAX] Y Max = [YMAX] Z Max = [ZMAX])"
    "(X Length = [XLENGTH])"
    "(Y Length = [YLENGTH])"
    "(Z Length = [ZLENGTH])"
    "T1"
    "G17"
    "G21"
    "G90"
    "G0[ZH]"
    "G0[XH][YH]"
    A thousand thanks!!
    Gabriele
    Kaos Creations Italy
    #2666 kaoscreations, May 21, 2024
  27. sharmstr
    I can only guess that you have something in your tool notes that's causing the problem. Probably multiple parentheses which isnt allowed. In other words, if your tool info has parentheses, you need to remove them.
    Bad: (Toolname Engraving (7.5�, Tip 0.005 - 1/4"))
    Good: (Toolname Engraving 7.5�, Tip 0.005 - 1/4")
    Post the gcode file so we can see the issue.
    #2667 sharmstr, May 21, 2024
  28. kaoscreations
    Hi and thanks for the reply. This is one gcode made with the postprocessor modify. I think that i've to delete one of (, correct?
  29. sharmstr
    Yes. This line
    (Toolname Fresa a candela (6 mm 1000 800) PASSATA 2.5 mm)
    Needs to be
    (Toolname Fresa a candela 6 mm 1000 800 PASSATA 2.5 mm)
  30. johnka
    johnka New
    I have a very old computer (MacBook 2,1) which is running Linux Mint 21 and I use it with CNCjs. I use Firefox for CNCjs.
    I tried OpenBuilds CONTROL but when I upload a gcode file it becomes unresponsive.
    WebGL is not available so I disabled the 3D view and it's working better.
    Is there any way to disable the 3D view but keep a 2D top view of the gcode (just to get a preview of the cut to verify it's the correct file)?
    I don't want realtime position indicator or interactions, just an overview. In CNCjs I get different predefined views of the gcode file. Would that be possible to implement something like this in OB CONTROL?
