OpenBuilds CONTROL Software
  1. Peter Van Der Walt
    v1.0.149 will be up in a couple mins: Fixes the multiline macros bugs :)
  2. Jack D
    Jack D Well-Known
    Staff Member Builder
    First, congrats on the new baby. Thank you for an in depth explanation of how the software functions. Unfortunately, my programming and coding skills are nearly non existent, but I do think I understand what you are saying for the most part. I think the software GUI layout, and basic functionality of it, is well done. I will just have to accept that it's just not meant for everyone, at every level. Maybe with some more tweaking, it can be though. I thought I seen a post saying rpi wasn't capable of doing WEBGL, but here it is doing it. Maybe it's an experimental software based setting, but it does work! Anyway, here is are 2 files. The roughing file will load with preview and the finishing file crashes the program on my systems. Note that both will load on my beefier desktop setup.
    @sharmstr worked through getting webgl working - I have to add it to the documentation still!
    Thanks for the files, will check when I am back in action!
  4. sharmstr
    Just tested and it appears to be working. Thank you for that! I'm going to open up a request on github to maybe change the color of the gear icon on the macro button when you mouse over it. A few times I've clicked just near it when I've wanted to edit the macro and it ran the macro instead :)
    MaryD likes this.
    :) Please do! Git issues is my todolist! If i just promise to do it here, i might forget :)
  6. Jack D
    Jack D Well-Known
    Forgot to mention that you will need to delete the T1M6 line from the gcode if you try to run it .
  7. rob ten tije
    on linux need some kind of permission
    if try to connect the usb port what ever port get error permisson dennied
  8. sharmstr
    It was discussed earlier in the thread here: OpenBuilds CONTROL Software
    Let us know if that works.
  9. Nick W
    Nick W Well-Known
    is there a known issue with the Feedrate override setting? Sometimes it works, other times it ignores the 20% it is set at and runs at what seems like 100%. Sometimes I will set it to say, 20% then it automagically changes to a different, higher %. Is there a recommended order of operations to always get it to work? FYI I'm using it with a BlackBox
    T
    Drag, and lift. Once you release the mouse it then sends the override commands to adjust the feedrate. gnea/grbl
    Here's how it works under the bonnet
    They way Grbl works is we cant tell it "go to 150%" - you have to look at the last reported feedrate override (in Ov: field of '?" response) then calculate the delta to get to the commanded override. Send requested amount of + or - commands to get there...
    Then wait for FRO to come back in next status message: Update the UI (move slider to actual value so you know what Grbl is doing)
  11. Nick W
    Nick W Well-Known
    So when I slide it to 20% and it does not change the speed, that is unintended behavior. (bug) It broke an o-flute bit on me yesterday.
  12. Peter Van Der Walt
    Grbl 1.1f? I'll check when I'm in the shop tomorrow but used it over the weekend and it worked. Anyone else?
  13. sharmstr
    I've kept out of this one, but since you asked....
    I did notice once where I thought the feed rate didnt change. I was cutting a 380mm diameter, in which each trip around is one command. I chalked it up to maybe Control (or grbl) didnt have realtime (mid-command) feed rate adjustment. So when Nick posted the other day, that was going to be my response. However, I stopped myself and decided to do a quick test. I issued a G1 Y1400 F500 command via serial. While it was executing, I changed the feed rate by clicking and by sliding. I couldnt get it to NOT change the feed rate. It worked every time. So, I decided to not respond and let you handle it :)
    I know I probably should have tested G3 as opposed to G1, but I was being lazy.
  14. Peter Van Der Walt
    Cool thanks for speaking up :)
    Will try and get into the shop tomorrow
  15. Peter Van Der Walt
    [edit: See post later on, v1.0.150 will be a fix for the Sliders]
    #375 Peter Van Der Walt, Apr 11, 2019
  16. Peter Van Der Walt
    Sidenote, hows Spindle override at 200% gonna work. 100% = max pwm already... Might have to check that with Sonny too. [edit] dropped him a mail [/edit]
  17. David the swarfer
    if your max feedrate is 2000mm/min and your F word is F1000 then 200% of that is 2000mm/min. no problem there.
    similarly if F is less than 1000mm/min then 200% is within the valid range. GRBL will have to trim for values that would exceed the max rate.
    note it is 'feedrate override', so it is not setting the feedrate itself it is adjusting the value set by the last F word.
    SpringBob likes this.
  18. Peter Van Der Walt
    Not feedrarte, that ones obvious. I said Spindle :)
    Sonny replied:
    "It increases it until it’s at the max PWM. After that it stays at the max PWM."
    Still makes sense though. If the S value is 50% then 200% override = 100% power (mainly thinking lasers for tool override, spindle = not many users here with spindle under control) . If S is already 100% then it has no effect.
    Same with feedrate, if a override exceeds configured maximum feedrate the effect is nothing.
  19. Chillimonster
    Chillimonster Well-Known
    One of the things that catches me out on the OB control software is the 0.1 / 10mm / 100mm jog steps. I've been positioning the Z and forgot it was on 10mm!
    On UGS the Z travel is seperate to the X & Y. This makes sense (to me anyway) as i want to fine tune my Z movements to position and the X and Y i usually need to move in larger increments.
    Is it on the cards to separate the Jog distances for the Axis?
  20. David the swarfer
    aye you did, obviously i should wake up before typing :ROFL:
  21. Peter Van Der Walt
    All good man! Happens to us all sometimes
  22. Peter Van Der Walt
    At this time, no.
    Mostly because I can't find a way to introduce it in a way thats pretty, and easy. Easy being the key thing. I dislike dropdowns for steps size (;
    Chillimonster likes this.
  23. Peter Van Der Walt
    @sharmstr @Nick W v1.0.150 is out :) with improved override sliders
    Please update and check if it works better for you guys now? (Considering it a little beta till I get feedback from more testers hehe)
    #383 Peter Van Der Walt, Apr 12, 2019
  24. sharmstr
    Will do when im back in town. Headed out to moto gp in Austin for the weekend!
  25. Peter Van Der Walt
    Awesome!!!!
  26. Nick W
    Nick W Well-Known
    It is working so far. I have used it for a few days and many projects. It works and now the -% are gone. :). thank you, I'll let you know if i run into anything else.
  27. Shqipetari
    Hey oddball question: Is it possible to have a time countdown to job completion?
  28. sharmstr
    Shqipetari likes this.
  29. Shqipetari
    I appreciate that! Even an estimate would be great. it's better than what I have now. Figured I'd ask, I cannot program unfortunately
  30. Mark Carew
    If you look at the bottom of the OpenBuilds CONTROL window during a job. There is a green progress bar there that helps at a glance to see the jobs position
