Interface Cancel / Abort
Discussion in 'General Talk' started by Robert-Lee, Jan 23, 2021.
  1. Robert-Lee
    Anyone using the interface with the switching relay power strip from openbuilds? Wondering what setting needs to be changed in order for the cancel / abort button to work. When I use the button, the router stays on and the XYZ stops in its place. Then, there isn’t capability to do anything further with the interface. I’m forced to shut down the router, shut down the interface/black box, restart all equipment. Turn router back on. Re-probe and reload the job. There has to be a more efficient method. I am current with firmware v1.43. By the way, other than this small programming issue, the interface works exceptionally well.
    Grbl is supposed to stop the router on abort, so will investigate it for you on Monday. Thanks for the bug report
    Robert-Lee and sharmstr like this.
  3. Robert Drisaldi
    Hi Peter -
    Has your team made any progress resolving this bug?
    Robert-Lee likes this.
