INTERFACE CNC Touch Controller
Discussion in 'Other Builds' started by OpenBuilds, Dec 15, 2020.
  1. sportsracer
    Of course not. :(
    Looks like I need to do the Q25 mod, BUT my interface box did not come with the TVS Module.
    Don't really need it. We included it for a while for users to have a little extra protection after Q25 removal, but honestly thats to protect the BB against stupidity (dead short on V+ to GND, when clearing short with power on, you can cause the onboard regulator to surge, TVS just protects against that). We stopped shipping them as the old versions are scarce, and if you still have one, by noe surely you arent just wiring it up (been a couple years. Most oops wiring risk is at the beginning). Just don't short V+ to GND :)
  3. sportsracer
    Q25 removed and everything is working as it should. Thank you so much for your help and patience. Reading is fundamental. ;-)
  4. Bigbanko
    Bigbanko New
    Is there or will there ever be the functionality to import a macro created in Openbuild software onto the USB and run it? Similar in concept to the probing function I guess.
    Gcode macros: simply create a file on the USB. Make yourself a Macros folder or something to make it easier to find. Run the macro just like you would a job
    Javascript Macros : no, as the Interface is a different architecture
  6. Bigbanko
    Bigbanko New
    Yep, worked a treat.
  7. Peter Sesselmann
    where do I find the latest firmware for
    INTERFACE CNC Touch?
    Docs.openbuilds.com > Interface > Firmware Update section. Latest is V1.57
