Workbee 1015
Discussion in 'CNC Mills/Routers' started by arcrunner, Nov 9, 2018.
  1. arcrunner
    arcrunner Well-Known
    arcrunner published a new build:
  2. arcrunner
    Serge E. likes this.
  3. caseyjaybenson
    Where did you find your 50inch lead screw?
    Have you had any problems with it being that wide?
  4. arcrunner
    I got the original kit from AliExpress, and since it's from China, they'll cut you what ever length you what, haha. They won't ship it unless you buy at least 1 c beam of the same length because the leadscrew is almost sure to get damaged by itself.
    There is some whip if you're working at the far end so of the axis, but it runs fine at this time. Belt configuration would be fine, and maybe a little faster too.
    Originally, I had a 1510, and I purchased additional extrusion to make it 1500x1500. However, that meant I only had 2 1500mm leadscrews, so I would have to change the x axis to belt drive. I did, and ran it that way with double belt for a week or so. Then I cut it down to it's current configuration so I could do all leadscrew setup.
    I may just convert this to ballscrews next month, so I'll end up either cutting new plates for that.
  5. Giarc
    I have 1500 mm long Y axis on my build. I sourced 1/2 inch 5 start lead screws that move 1/2 inch per rotation from McMaster Carr. Of course, then you need new bearings and couplers. I have no whip that I notice. I did have to source different anti-backlash nuts (I made my own). They fit in the cbeam channel, but I ultimately did not use cbeam due to back-order issues at the time.
  6. arcrunner
    At 1/2" or approximately 12mm, sounds like they would be pretty solid, I was considering going to 12mm ballscrews since I'm ordering a bunch of them for a different project, and could get them in the same order, but the McMaster Carr one looks good too, and I guess you don't need to oil them as much either!
  7. Giarc
    I have never oiled them. I use delrin anti-backlash nuts and have not noticed an issue.
  8. caseyjaybenson
    Excuse my newbie questions, Should I order the KIT from OB and then the extra parts from McMaster Carr to make things simple? If so can someone share the parts list I should order? I appreciate your time greatly. Thank you gentlemen.
  9. Giarc
    I would first figure out what other parts you would need to change from belts to screws. I went with metric bearings because they were easier and cheaper to source, but that meant I had to have my 12.7 mm McMaster Carr lead screws turned down to 12 mm. Luckily for me, I had a friend that had a lathe and said he could do it. The best way to do this is to download the model in Sketchup (or whatever CAD software you prefer) and add the parts and modifications. I would think that it would be a simple modification to get new shaft couplers, bearings, and possibly enlarge the holes for the rods on the end plates. Search Amazon or McMaster Carr for pillow block bearings If you attach them on the outside of your plates like I did, you can apply a little tension on the screw which will aid in reducing whip. I used some similar to this. You must also remember that your holes may affect you plate mounting so they wold most likely have to have counter bored holes with the bearings attached first then the plates attached. That way the screw heads would be flush with the surface and not interfere with the plates attaching to the Cbeam.
    The hard part is making the anti-backlash nuts to fit into the channel because you need to make (or purchase a tap). To make my nuts, I measured the distance from the inside edge of the gantry plate to get a feel for the maximum thickness the nut could be and I was able to make one fit. However, I lost those files due to a hard drive crash. I started my design by down loading and modifying the Openbuilds 8mm anti-backlash nut. This is a great exercise (if you are a beginner) in using CAD software. If all you want to do is carve 2.5 D objects (signs etc...) then I would just buy the kit as is and not worry about the screws. If you go the Sketchup route, you can print 1:1 templates you can affix to the plates which can be accurately used to drill your holes. I built my entire machine by hand cutting and drilling all my aluminum plates this way. I linked that build in my previous post.
    Also, I would buy the kit. It would be so much easier than trying to buy all the components individually. Plus if for some reason the screws do not work out, you still can use the belts. Another easier option may be to do something similar to this: Project - Ox Upgrade Kit
    joe williams likes this.
  10. arcrunner
    Regarding the nut for the 5 start acme, what do you think of the anti backlash nut that's already out there? Similar to the one CNC router parts sells? Just curious as to the main difference other than the construction of course.
  11. Giarc
    I would assume it works fine. However, according to their drawings, it is 57.15 x 24 mm so it will not fit in the cbeam channel. There are also these if you choose an alternative mounting method. dumpsterCNC - anti-backlash solutions for home and industrial linear motion
  12. arcrunner
    Used the 1015 cut these rings out of wood and resin blocks I made, then chucked them onto a corded drill to sand and shape, finished with a few coats of CA. For the full wood ring, the end grain wasn't so appealing so I use my plane to cut a shaving to wrap around the outside, hopefully that gives it a little strength too.
    Rick 2.0 and GrayUK like this.
  13. Rick 2.0
    If you have the time it would be greatly appreciated if you could post a writeup on these in the Projects section of the forum. I think a lot of members could draw inspiration from this.
    Mark Carew and arcrunner like this.
  14. arcrunner
    Sure! I'm going to do another batch over the next few days so I'll try to document it this time!
    Made a few test items out of spare ply before I move do them in some hardwood for a local convention coming up currently cutting these out of Birch ply at 35mm/s, will see how much I can push it in some hardwood!
  15. arcrunner
    Made a cupcake/donut tiered stand, 5mm cedar ply, used a 1/8" 2 flute carbide endmill at 30mm/s, 2.5mm DOC so I could do it in 2 passes.
    Got my 1/16" endmill bits in yesterday, doing some test cuts today!
    GrayUK likes this.
  16. arcrunner
    5 start 1-2-10-ACME-DELRIN-NUT-BLOCK-RH-for-acme-threaded-rod-CNC-3d-printer
    I came across these the other day, they are advertised as 1-7/16 inches tall, so they look like they might fit into the cbeam just perfectly. would be a good test for 5start 1/2 acme screws. I'm also contemplating moving to rack and pinion and large vbearings instead of the poly wheels, with a large x axis, they slip too much for me. v bearings may have a tighter lock, in addition to a rebuild of the plates
  17. sharmstr
    Those nut blocks are the same ones I used. They fit fine.
    I made a guide to drill mounting holes in the plates
  18. arcrunner
    how's the whip on the long axis? (I'm assuming your 1510 has the 5 starts on all the axis, correct me if I'm wrong). It would be an easier mod for me to do 5 starts instead of rack and pinion, but that option is still there.
  19. sharmstr
    No whip at all. So far I've only done the Y axis. Z will stay with the default 8mm. Really need to get the X axis done. Check out my build (starts half way down) for more info on what I used and how I lined everything up Shawn's Workbee 1510
    arcrunner likes this.
  20. arcrunner
    I was trying to find your build, but it wasn't showing up on your profile, go figure. What kind of feedrates/DOC/material are you able to achieve with this setup?
  21. sharmstr
    I think I need to change the build from in progress to finished in order for it to show up.
    Screws are slower than belts. With high torque motors, 48v power supply and DQ542MA drivers I could rapid at 7000mm/min. Then OB sent me a Blackbox to try out so I had to switch to a 24v power supply which meant I had to reduce my rapids to 5000mm/min.
    My doc/woc/feedrate while cutting wont mean much since I still have a belt on X. To me, what really made a difference is linear rails vs the wheels.
  22. arcrunner
    My build is still in progress, I remember seeing your build on the main page, but couldn't find it in your profile.
    I would say there's still value in your cut parameters since you have to go by the slower axis. Having trouble getting rails shipped to me, so it's 3/8 vbearings on steel rail for now, trying to get hardened rail shipped. Having a slight bit of trouble getting the 1/2" screws out here, due to the length and that it's going airmail.
  23. Rick 2.0
    Yes, for some reason it doesn't show up on her profile page but it's easily reached just by clicking on the 1 next to builds in the box that pops up when you click her avatar.
