Openbuilds Table Top 50w Co2 Laser Cutter/Engraver
Discussion in 'Laser Cutters' started by pedrofernandez, Jul 5, 2019.
  1. pedrofernandez
    pedrofernandez Journeyman
    pedrofernandez published a new build:
    Jdog, Giarc and GrayUK like this.
  2. GrayUK
    What an Excellent job!!!!! :thumbsup::thumbsup::thumbsup::thumbsup::thumbsup::thumbsup::thumbsup::thumbsup::thumbsup::thumbsup:
    Great workshop as well. :D:D
    Really Well Done.
    Gray
    pedrofernandez likes this.
  3. Mark Carew
    Wow! such a great Build. Thank you for the in depth share this will go a long way in helping others learn and this is what OpenBuilds is all about!
  4. pedrofernandez
    Welcome Mark, uploaded the Z axis idea just know, also if you notice any grammar issue that you think should be corrected let me know, English is not my primary language
  5. Ryan James
    I do have one question. You're worried about the Y axis staying square so you're using a single stepper but going with a 4 stepper setup for the Z. Now you're introducing 4 points of failure that would cause the bed to be off level. How are you compensating for that?
    Alex Chambers likes this.
  6. pedrofernandez
    Im not sure what are you trying to address with your concern for a Z axis motion on a co2 laser cutter, the primary reason of the Z axis is for focusing purposes, meaning the work bed will not be moved during a cut, this is not a 3d printer with a Z axis constantly in motion, there is not Z axis gcode involved during a laser cut in this machine, the z table moves by just a "jogging" button on the laser control panel, if one or multiple motors fails there is no risk or hazard involved at all, on the contrary Y axis it is a big concern for common reasons.
  7. Ryan James
    I guess if you're not planning to move the Z during a process, that's a good point. However, you'll have to level the bed more frequently before cutting. My plan is to get the Z to move during cuts since a cut focus should be different than an engrave focus.
  8. pedrofernandez
    yes a single motor closed loop belt it is the option for your type of engraving, I always double check my focus for every cut job, the primary reason for the 4 motor setup is to lift the massive 20lbs chuck rotary, to do that with a single motor, a pretty decent nema23 at least will be require with nice closed loop belt and pulley setup, I did the research the 4 motor setup end up cheaper.
    GrayUK likes this.
  9. Naeem
    Naeem New
    This is an awesome build! Thank you for so much detail on the design. I was looking at the photos and the parts list... it seems that there are some items that you forgot to add. Would you be able to add those too so that we can estimate how much a build like this would cost to make and also attempt one ourselves. I am very excited to work on this as my next project. Thanks.
  10. pedrofernandez
    Some details are missing I will update the part list this weekend, this is one of the more difficult task to do!!
  11. Naeem
    Naeem New
    Thank you so much... I look forward to it. Also, have you had any challenges so far with your machine? Or things you feel you would do differently on your next build?
  12. sharmstr
    I dont doubt it but would be very grateful. I've spent the week trying to decide if I should build my own or get a crap one off of ebay and upgrade it.
  13. Guy Snyder
    You did a great job on this build. I see that you used a Linear Rail Guide with Sliding Guide Block for the X axis. Did you consider using it also for the Y axis? I was thinking of doing this and wondered if it would be a good idea or not.
  14. pedrofernandez
    You can use any of them, wheel setup or linear rails, but Pro lasers use linear rails on both axis, also be ready for a pocket injury when buying good original rails those are not cheap.
  15. Mark Carew
    Well.. another work of art is born! @pedrofernandez you did it again man this thing is a true beauty, seriously nice work.
    I will be sharing this one in the morning meeting for sure!
    Great build and the results speak for themselves .
    p.s. Love it's emblem! :thumbsup::thumbsup::thumbsup:
  16. ADEBOYE OLADIMEJI
    Nice work there, I will Need your assistance in putting me through with materials to buy and how to build a 4060 XY axis stage for laser machine. Thanks
  17. Flyboy369
    Flyboy369 New
    What an awesome build!! This is a great project and almost exactly what I have been looking for. Are you planning on publishing the complete BOM or parts list?
    Thanks for publishing this!!
  18. Clintj
    Clintj New
    +1 this looks amazing thank you so much for sharing I can not wait to get started on the build!
  19. Don Schaening
    What's the estimated cost of this complete build?
  20. msaeger
    msaeger New
    Looks very nice! Thanks for all the photos.
    Can I ask why use the linear rail on one axis instead of the v wheels?
  21. glenn martonic
    love it....outside the box....reading and listening to your "why" i did it this way......made me rethink areas of my build.....super clean
  22. Chadfarmer
    Wow u need to sell a kit or the start of a kit I have a acro 1010 would love to d ok this with it.
