XYZ Touch Probe with V Bit
Discussion in 'General Talk' started by John Ford, Feb 2, 2021.
  1. John Ford
    John Ford New
    If I want to use a V bit with this probe what do I set as the bit diameter? I am using a 60 degree V bit.
  2. ljvb
    ljvb Well-Known
    You don't, you use it as a z probe only
  3. sharmstr
  4. ljvb
    ljvb Well-Known
  5. Alex Chambers
    Use an accurately measured rod to probe X and Y whatever bit you are using. The flutes/cutting edges on a bit means you can't rely on getting an accurate probe on both X and Y. Then change to the bit and probe Z.
    John Ford likes this.
  6. Giarc
  7. John Ford
    John Ford New
    Thanks for the advice. I have decided to opt for a piece of 1/4 inch brass rod as I could not find any reasonably priced vermont gages in Australia - shipping from US was more expesive than the product!
    Giarc likes this.
  8. Giarc
    That will work just fine. However, measure it with a caliper to be sure it is exactly 1/4 inch. If it isn't, use the value you measure and it will be as close to perfect as possible.
    Alex Chambers likes this.
  9. John Ford
    John Ford New
    Okay. Thanks for the advice
  10. Brian Hagen
    So my assumption is the probe is setting the zero point for x and y based on the middle of the 1/4 inch reference bit. If you set that and swap to the v-bit (and set the z axis accordingly), the point of v-bit should exactly hit the exact same point (where the middle of the 1/4 reference bit referenced earlier).
  11. Alex Chambers
    Yes, that is correct.
    Brian Hagen likes this.
