X axis motor location...
Discussion in 'CNC Mills/Routers' started by Rafael Romero, Jun 19, 2019.
  1. Rafael Romero
    Does it matter at all if its on the left or the right? Seen most builds install it on the right side... my set up has better clearance if its on the left.
    Alex Chambers likes this.
  2. sharmstr
    No. But you either have to switch the motor wires or invert the motor direction in your setup. If it were me, I'd just keep the motors wired the same and invert it in software. If you're using a grbl based controller, you'd change parameter $3.
  3. Rafael Romero
    Awesome!! ty for the insight. Will check that line on the software set up and leave wires alone.
  4. sharmstr
    You might not have to change it. Basically, if you tell it to move X+ and it moves X-, invert the direction in grbl settings :)
