workbee 1510
Discussion in 'CNC Mills/Routers' started by Gee's, Nov 10, 2018.
  1. Gee's
    Gee's New
    Hi can some one help with a problem i have with my cnc machine its doing a proper circle some settings some where
    Regards graham
  2. GrayUK
    Hi Graham & Welcome :thumbsup:
    I'm afraid we'll need a better explanation and description of your problem. :(
    As well as details of your Programs and Controllers, before we can come up with any advice. :)
  3. Gee's
    Gee's New
    right thank you,
    Workbee 1510 Vectric cut 2d desktop using openbuild machine drivers plus X pro controller hope this helps
    Thank again
  4. joe williams
    joe williams Well-Known
    ...OK, but what is it doing?
    Rick 2.0 likes this.
  5. Gee's
    Gee's New
    Hi thanks for helping, it is not doing a true circle and on the y axes the slave motor keeps stopping and trowing it out of sink just wondering if i have a problem with the CNC xPro V3 Controller light goes out when it does it, i have not calibrated it yet but every thing is square and level and in line
    Regards graham
  6. Scadam
    Scadam New
    Although this is not an answer, i am experiencing the exact same problem - the router does not output a circle, it is almost elliptical.
    What i have done to try and resolve this:
    - Re-tension both A and Y belts. (4-5 times now)
    - Re-run belts
    - reset settings and applied again in software
    Observations:
    - Slave axis (A) is about 42mm from the end plate when homed, the Y is 40mm. Always home to this position.
    - light does indeed go out *sometimes* on the CNC xPro v3 Pro controller.
    - tension of belts doesnt seem to affect the outcome, always 2mm difference between Y and A.
    What i havent tried is swapping the Y and A and seeing if that makes the problem reversed.
    Any advice of what i can try next? hopefully this will help Gee as well.
    Gee - could you please enlighten me to the process you are using for calibration? I followed the build along video.
  7. sharmstr
    Have you calibrated your motor steps? I had issues with circles until I did this:
    I cant find the post now, but the xpro stepper lights will be green, red or off depending on movement. I thought I had a motor issue as well, but after calibrating, all is well now.
  8. Gee's
    Gee's New
    Hi calibration i just cut 250mm x 250mm and measured it and it is the correct size with all the settings from openbuilds my cnc machine is a workbee 1510 but all screw driven i did come to the conclusion that the board was faulty, changed it did it again with new board, y axis clone kept stopping, i had no fan on the board may be it was over heating installed a fan today aligned it all up, went good so far
  9. Scadam
    Scadam New
    So i had done the calibration previously and it did not have any effect however it led me to re-check all the wheels pretension as per the video from Ooznest. After completing this process (the wheel were waaaay too tight) i re-calibrated per the video you posted and what do you know, it worked!
    Thank you for pointing me in the right direction, i was at a loss.
    Adam
