WorkBee 1510 - First CNC Build
Discussion in 'CNC Mills/Routers' started by Scadam, Nov 20, 2018.
  1. Scadam
    Scadam New
    Scadam published a new build:
  2. Mark Carew
    Great Build @Scadam it was fun to follow along with the adventure, thank you for sharing. :thumbsup:
  3. Scadam
    Scadam New
    If anyone is following this - i have run into an issue which i haven't been able to resolve.
    The CNC now seems to be skipping steps, resulting in skewed / missed cut areas and a couple of broken bits when it has "forgotten" a Z+ operation and plowed into the spoil board.
    My question:
    1. How best can I narrow down the cause of the skipped steps?
    2. What can i do to test this without breaking / damaging bits, spoil boards, router, etc?
  4. GrayUK
    So. Are you saying it is Y-axis and Z-axis losing steps? :rolleyes:
    After each error, what are you doing to check/correct it? :)
  5. Scadam
    Scadam New
    I initially thought it was out of calibration again, calibrated again and movement is perfect when jogging.
    The first time it happened I put it down to using fusion 360 post process as I was attempting different tool paths I hadn't used yet, second time I tried with a simple circle made in cam.opencad and straight to controller.
    I haven't done alot more as I really am at a loss as to what I can try or tweak.
    The issue seems to be axis agnostic as I have had issues in x y and z in the last cut, this is why I have made the assumption steps are being skipped / dropped.
