Weird toolpath with Control
Discussion in 'Control Software' started by darrepac, Jun 17, 2020.
  1. darrepac
    darrepac New
    Hello
    The toolpath created by Fusion 360 sounds good but the one shown in Control is really weird in some places.
    I opened the same GCode in ncviewer and the toolpath seems ok in it so I guess it may be an issue in Control to be checked?
    Code and pictures attached Control with problem.png NCviewer withour problem.png
    The viewer does a best-effort but can fail on some arcs etc
    It will run fine even if the viewer failed at it
  3. darrepac
    darrepac New
    yes, was also my guess but if such report can help to improve the things... was my intention
    Ahh sorry, yes indeed. In this case though David reported it a couple days ago, just haven't gotten round to fixing the Parser yet. sorry!
    Please do post your file and I'll give it a test while I work on the code
    #4 Peter Van Der Walt, Jun 17, 2020
  5. Craig & Silas
    This is sorta similar problem: Using Vetric Desk Top Pro and OB Control with OB Black Box. Making an inlay of letters cut out the pockets just fine, started running the inlay and I get two errors. Here is a short section of code:
    T1
    G17
    G20
    G90
    G0Z0.8000
    G0X0.0000Y0.0000
    M3S16000
    G4 P1.8
    G0X1.5140Y1.0766Z0.2000
    G1Z0.0000
    G1Z-0.0353
    G1Z-0.0367
    G1Z-0.0382
    G1Z-0.0397
    G1Z-0.0411
    G1Z-0.0426
    G1Z-0.0441
    G1Z-0.0455
    G1Z-0.0470
    G1Z-0.0485
    G1Z-0.0499
    G1Z-0.0514
    G2X1.6240Y1.3238I0.0925J-0.0595F30.0
    G1X1.7140
    First problem is a missing feed rate for line 10 (G1X1.7140) easy to fix I just added F35.0 and machine continues on to
    line 23 (G2X1.6240Y1.3238I0.0925J-0.0595F30.0) an error code of 33 Motion command target is invalid.
    Where are these errors originating? Seems like 3 possible places Desk Top Pro, Black Box or Control. How do I fix this?
    PS Running simulation on Control looks just fine no stops occur.
    Check Max Travel settings in Grbl Settings
    Check that machine is homed and zeroed properly before starting the job
    Check that Job fits in the working envelope of the machine
    Have a read through the Grbl Wiki at github.com/gnea/grbl/wiki
  7. Alex Chambers
    Also check that you are fully up to date with the Vectric software. If you upgraded recently to version 10.5 there have been problems with several post processors - missing feed rates and error 33 on arcs and spiral ramps. Which post processor did you use?
    The latest patch (V10.505) claims to have fixed those issues.
  8. David the swarfer
    I think you are using the wrong post processor as GRBL Gcode should not include a T1.
    Also, the arc parameters are incorrect
    arc from
    G0 X1.5140 Y1.0766 Z0.2000
    to
    G2 X1.6240 Y1.3238 I0.0925 J-0.0595
    does not define the correct center for those endpoints, that is what error 33 means.
    this is what bCNC displays for that arc (it tolerates the errors but displays the wrong thing as a result).
    the blue highlighted segment is supposed be be the arc from bottom to top, ie the straight line is NOT correct.
    The are many arcs than can go from
    X1.5140 Y1.0766 to X1.6240 Y1.3238
    it all depends where the center is defined by the I and J parameters, but these ones are wrong.
    Here I have plotted the given points...
    clearly there is no arc that fits between those points with that center.
    So the problem is in Vectric or in the Vectric post.
  9. Craig & Silas
    That did it, downloaded the patch and it ran fine. There may be an overshoot on the depth of cut. I will run a test tomorrow and see, if so I will send a note to Vetric. Thank you for the help.
