Travelling a continuous line
Discussion in 'Control Software' started by Chris Drake, Nov 14, 2018.
  1. Chris Drake
    Hi.
    I have built a long arm quilter for my wife and am looking to automate it. As the device is essentially a sewing machine that moves X & Y it needs to A. start in a specific place and B. travel in one continuous line.
    I have played around with a simple drawing of one line that criss crosses it's self and then loaded the SVG file into OpenBuilds CAM - GCODE Generator however the result is that I can't get it to simulate a continuous line.
    Is this possible or should I be using other software.
    All the best
    Our CAM is optimised for Closed path vectors. A closed path has at least 3 points. A Line only has two, so no it wont work unfortunately.
    But simple linear moves can easily be written by hand:
    G90; Absolute mode
    G0 X0 Y0 ; Where X0 Y0 is the first point, could be X10 Y500 or whatever
    G0 X100 Y100; ; Where X100 Y100 is the Second point, could be other values too.
  3. Chris Drake
    Thanks for the swift reply. Going to have to rethink.
    Chis,
    #4 Peter Van Der Walt, Nov 18, 2018
    THE LINK, Mark Carew and Chris Drake like this.
  5. Chris Drake
    Hi Peter.
    You're a star. Having extensively searched the net I didn't find this. Some time you can find stuff straight away and others....
    All the very best
    Chris.
    (; pure luck man, it popped up on Hackaday today CNC Embroidery Machine Punches Out Designs a Stitch at a Time and i remembered you as soon as i saw it
  7. Mark Carew
