Touch Interface overrides speed
Discussion in 'Interfaces' started by Brad Guest, Oct 24, 2021.
  1. Brad Guest
    I have set my movement & plunge rate very high in ASPIRE ( as shown inn picture ) I then put the project on a USB & take it to my Openbuilds Touch Interface . I then up the speed override & the Feed override to 200 % ( as shown in picture ). The problem is it seems it is ignoring the speed I set in ASPIRE & only upping the speed to what the Interface is set at. This is not fast enough. How do I get it to use the speed set in ASPIRE ?
    #1 Brad Guest, Oct 24, 2021
  2. sharmstr
    check your max feed rate in the grbl settings
  3. Alex Chambers
    Can your machine reliably achieve 600 inches/min (15240 mm/min)?
  4. Brad Guest
    I set it super high just so I could visibly confirm it was not going faster . The speed it is travelling right now is no problem , no deflection , no burning. It can def handle more speed
  5. Brad Guest
    Where do I find the max feed rate in the grbl settings
  6. sharmstr
