Things you didn't Know about OpenBuilds Software
Discussion in 'Control Software' started by Peter Van Der Walt, Jan 16, 2019.
  1. David the swarfer
    if the MPG pretends to be a keyboard and can be configured then you can map its buttons to the keys that CONTROL uses.
    or you may be able to use software like Qjoypad (which is for linux) to map from the device to keystrokes.
    QJoyPad Alternatives and Similar Software - AlternativeTo.net
  2. arc1979
    arc1979 New
    Is there a way to control an A axis (rotary) with the Open Buillds Control software?
    Grbl supports 3 axis only. But checkout Wrapping around X or Y with Vectric
  4. Barry_W
    Barry_W New
    I really like this software, previously using UGS. It would be great to have some options/buttons to jog 2 axis' simultaneous, ie moving X and Y to position.
    Great job thanks.
    rscamp likes this.
  5. Ronald4418
    Ronald4418 Well-Known
    I'm coming over from UCCNC and Mach3 and already have a USB Pendant connected to my system. Will I be able to assign the buttons on the Open Controller to use it instead of a keyboard or my Cell Phone?
  6. sharmstr
    If you can program it to mimic keystrokes, then yes. Install the software, click on Wizards and tools, then keyboard shortcuts. You'll see a list of what you can control via the keyboard. You can also use your phone to control it.
    But, in case you dont know, it will only work with a grbl based controller.
  7. Barry_W
    Barry_W New
    Has anyone ever experienced such an error? I run a job today and halfway in the cnc stopped and i noticed this ridicules z axis depth.
  8. David the swarfer
    You probably had a USB communication problem. Use a good quality and short USB cable, keep power cables away from the USB cable.
    Peter Van Der Walt and Barry_W like this.
  9. Barry_W
    Barry_W New
    Yea had the same thought. Will try that and may tie on some ferrite beads. Thx
    #100 Peter Van Der Walt, Nov 20, 2020
  11. Rhett E
    Rhett E Well-Known
    Do you have a USB cable/brand you recommend? The shortest I can realistically go is about 6ft. Also, in regards to EMI, should the Blackbox and PSU be mounted X distance apart from each other? Thank you
  12. Peter Van Der Walt
    - shorter is always better
    - the official USB spec limits all USD wiring to around 1.2m for optimal performance. 6ft is a bit outside spec
    - good cables have Ferrite cores on one or both sides
    - you can use a powered hub in between but note longer distance, extra hops, all increase likelyhood of EMI messing with Communications.
    -keep in mind this is a CNC in a workshop, not a office. Its an extreme environment, dust, vibrations, static electricity gets generated from all the moving and cutting, and dust extraction hoses too. Don't expect what works in an office to work in such an environment. Put the PC near the controller. Rather make longer cables from controller to motors etc
    #102 Peter Van Der Walt, Nov 21, 2020
  13. Ronald4418
    Rhett E and Peter Van Der Walt like this.
  14. Ronald4418
    Curious, will I be able to create point clouds using the Probe Port? I've been studying bCNC and for all intents and purposes this controller package looks exactly like bCNC except for the 3DWeb GL interface.
  15. David the swarfer
    Yes. bCNC will scan a surface and save the points to a file.
    It is setup to use that point file for wrapping flat Gcode around the probed surface so the format is not STL or STEP or any such, but a little php or python or ruby or perl scripting will convert any text file to any other. You may also be able to write a plugin for bCNC that does it all for you, plugins are all in Python.
  16. 2ler
    2ler New
    Is it possible to single step ( single block ) thru a program with the OpenBuilds controller?
  17. Peter Van Der Walt
    Not at this time. But you can paste line by line into the serial console while you test something. Otherwise people usually run the job normally
