Stainless OX Kit Build
Discussion in 'CNC Mills/Routers' started by Tucstrlly, Oct 25, 2017.
  1. Tucstrlly
    Tucstrlly New
    Tucstrlly published a new build:
  2. vic1962
    vic1962 New
    Hi I have difficulty downloading the file
    OX Revised Build Instructions.pdf stops at 25%
  3. Tucstrlly
    Tucstrlly New
    Not sure why. Try following the link instead. It will take you to the original word file. I just made a pdf from the word file.
    Eric
  4. Gvan
    Gvan New
    Any way to get a drawing for your centering Jig?
  5. Tucstrlly
    Tucstrlly New
    I just posted the product in my Shapeways shop.
    Bad Cat Designs by Tucstrlly - Shapeways Shops
    it was modified to fit my tap, the hole for the tap can be drilled out (carefully) if you need to make it bigger- or just modify the STL file.
    -Eric
