Spindle Speed Control
Discussion in 'CNC Mills/Routers' started by cwturner2, Jun 19, 2019.
  1. cwturner2
    cwturner2 New
    New to CNC and only had my Workbee 1010 for a week. Working with the WorkBee, I have not seen any method to control the router using g-codes. It all appears to be manual. Is there anyway to hook the Dewalt 611 router to a controller to automate these processes?
    Thank you for your time.
  2. sharmstr
    For speed control you can use something like the SuperPID: www.SuperPID.com - Super-PID Closed-loop Router Speed Controller I have one but have never hooked it up. I bought it before actually using the machine but have found that I rarely need to adjust the speed of the router.
    For simple on and off control, you can use an IOT relay. If you are in a location that uses 110v, then this one is available in the OB store: IOT Switching Relay Power Strip If you have the Blackbox, here's how to hook it up: OpenBuilds BlackBox 4X Documentation
    #2 sharmstr, Jun 19, 2019
  3. Felix_Hauser
    I was looking to replace my Dewalt Router for a Makita in order to have more RPM control and I stumped across this SuperPID. Looks quite interesting and cheaper than replacing the router, taking into account the new mount, new collets and so on. Not to mention that with this thing you can go all the way down to 5000 RPM instead of the 16000 RPM of the Dewalt or the 10000 of the Makita...
    I don't have any idea if I can get it to work with my Duet
  4. Alex Chambers
    There are pwm fan outputs on the Duet that you can use for speed control - you will probably need a pwm to 0-10V converter as well.
  5. Felix_Hauser
    I could actually set the fan jumper to 5v instead of Vin, right? Should be enough, I guess. Only thing, though, would be to power the fans directly from the PSU
