Slab Flattening Sled
Discussion in 'Other Builds' started by Stringhunter, Sep 9, 2019.
  1. Stringhunter
    hello I would like to build a slab flattening sled similar to the one in the photo but would
    Like to build it from extruded aluminum C track.
    I will move it manually but I would like to have two long side rails and a gantry rail. I would mount a router on the gantry so basically just like a CNC machine but I would like feet That will screw down to a work surface and a way to manually set the Z height and keep it locked.
    My issue is I have never worked with any of this material and I do not know the components I need. I have been trying to figure it out and have a sense that I need rails and a way to attach the gantry so that it will move. A gantry plate and a way to attach my router to it as well as some kind of feet to attach it to a work table. I would so appreciate any help in building a
    Parts list for the Open Build parts store.
    Thanks so much!
  2. Stringhunter
    By the way I built the sled in the photo last weekend and it works but the results are not perfect because of the lack of rigidity in the long aluminum tubing.
  3. Rick 2.0
    MaryD and Mark Carew like this.
