***!!!! simulator works but machine doesnt
Discussion in 'Laser Cutters' started by dr_chops, Aug 7, 2022.
  1. dr_chops
    dr_chops New
    Hi all
    just tried to cut a simple circle and while the simulator in the openbuilds control progrom runs fine when i press play on the machince to start cutting, the z axis retracts to max height and then the limit swtiches kick in
    any idea of whats going on? here is my code
    cheers
    lucas
    (Made in : Autodesk CAM Post Processor)
    (G-Code optimized for controller)
    (OpenBuilds CNC : GRBL/BlackBox)
    (Post-Processor : OpenbuildsFusion360PostGrbl.cps V1.0.30)
    (Units = mm)
    (Laser UseZ = true)
    (Drawing name : Untitled)
    (Program Name : 1001)
    (1 Operation :)
    (1 : 2D Profile2)
    ( Tool 1: Plasma Cutter Diam = 2mm)
    ( Machining time : 15 sec)
    G90 G94 G17
    G21
    (Plasma pierce height 2)
    (Plasma topHeight 2)
    (Operation 1 of 1 : 2D Profile2)
    G54
    (Plasma cutting with GRBL.)
    (This relies on homing, see Search Results for Query: G53 fusion | OpenBuilds )
    G53 G0 Z0
    G0 X42.83 Y2.5 F750
    G0 X42.83 Y2.5 Z15
    Z2
    M3 S1000
    G4 P1.8
    G1 Z0 F750
    G1 X38.5 Y0
    G2 X-38.5 Y0 I-38.5 J0
    X38.5 Y0 I38.5 J0
    G1 X42.83 Y-2.5
    M5
    G0 Z15
    M5
    G0 X0 Y0
    M30
  2. dr_chops
    dr_chops New
    Just to be a more of a pain in the *** it did cut one circle before packing up
  3. Gary Caruso
    Hello Dr. Did you remember to home and set your work zero? have to do that every time.
    It still jogs in the correct directions I assume?
    Gary
  4. dr_chops
    dr_chops New
    yup several times unfortunatly
  5. dr_chops
    dr_chops New
    i shouldve added that the machine will run home to 0 but when i hit start the z axis will start to climb and not stop
  6. Gary Caruso
    Which post processor are you using?
  7. dr_chops
    dr_chops New
    I’m I’m not sure I’m away from the machine but I downloaded it from the openbuilds page
  8. sharmstr
  9. dr_chops
    dr_chops New
    No I didn’t follow that one I’ll give that a whirl tomorrow
    thanks
  10. David the swarfer
    Code:
    G53 G0 Z0
    Z0 is always going to hit the limit switch, that is why there is an option in the postprocessor for setting a NEGATIVE offset to avoid hitting it. And the link is there to help you find information about it, but I think the top search hit it is a little out of date or not specific enough so I will update the link later. BTW the default value is -10mm so for it to be using 0 means you changed it (-:
    Meanwhile, read all about it here...
    Home, Fusion360 and G53 Z moves
