Shift + Enter in DRO not working correctly
Discussion in 'General Talk' started by brrian, Mar 20, 2021.
  1. brrian
    brrian Well-Known
    v1.0.294
    In the DRO, I'm trying to use the new Shift-Enter feature to change my Z & getting incorrect values.
    In mm mode:
    0 + Shift-Enter = 0 (correct).
    10 + Shift-Enter = 254mm (wrong).
    20 + Shift-Enter = 508mm (wrong).
    In inch mode:
    1 + Shift-Enter = 25.4in (wrong).
    2 + Shift-Enter = 50.8in (wrong).
    obviously a conversion issue...
  2. sharmstr
    Seems to be working fine for me.
    In mm mode,
    10 + Shift Enter, DRO shows 10mm, serial log shows Z10
    20 + Shift Enter, DRO show 20mm, serial log shows Z20
    In Inch mode
    1 + shift enter, DRO shows 1", serial log shows Z25.4
    2 + shift enter, DRO shows 2", serial log shows Z50.8
    Remember that serial log always shows mm, not inches.
    Perhaps you accidentally set Report Inches in Grbl settings. Disable it, CONTROL needs mm internally.
  4. brrian
    brrian Well-Known
    I just did it again. See attached.
    Before this I had run a program. When the program stopped, I switched from mm-mode to inch-mode, then did this.
    After I did this, I re-homed the machine, then played in the DRO and it all worked correctly & continues to.
    I don't know what's causing it... I'll try to, but it's definitely happening.
    & Peter, I just saw your post... just checked and Report Inches is disabled.
    Thanks for the check. If you wouldnt mind logging a bug report on github.com/OpenBuilds/OpenBuilds-CONTROL/issues/new i'll check it out on Monday.
  6. brrian
    brrian Well-Known
    Sorry... i just made a quick little test program. Ran it, 'shift+enter' changed the DRO afterwards & got the issue. The program I used is attached if you'd like to try to recreate it. It was made in VCarve using the OpenBuilds post processor, if that matters.
    Yip, need to force shift+enters G20/21 mode. Just log the reminder for me please. I am out and about and will forget by Monday. Forum too busy, git issue for a confirmed bug a better To Do list :)
  8. brrian
    brrian Well-Known
    sure, just did.
  9. Peter Van Der Walt
    Fixed in 1.0.295 or later (should be released later today)
    brrian and sharmstr like this.
  10. brrian
    brrian Well-Known
    Sweet - thanks. & BTW, Shift+Enter was a great way to handle this. Your idea?
  11. Peter Van Der Walt
    Its all a team effort, a lot of it comes from you guys, and some things just "feel right" (;
