Routing cables, power supply, mounting your controller
Discussion in 'CNC Mills/Routers' started by Charles Roseberry, Nov 12, 2019.
  1. Charles Roseberry
    Hi everyone. I have had my machine running for some time now. Enlarged it and have made a lot of small changes since I built it. One thing I've never done is route my power and wires properly so they are not cumbersome and in the way.
    So I'm reaching out for ideas on how to route the wires power supply and board. I have my controller board mounted on the back of my machine, and wires just kind of hang. my build is now about 35"x35" and when I'm in the front left corner its a stretch for my spindle and power.
    So, does anyone have pics of how they routed their larger machines wiring? I would really appreciate it. (I searched, but did not find any decent photos, and most of the builds I have seen do now show that part of the build) And lets be honest, I need to fix this issue.
    Thank You!
  2. Charles Roseberry
    Bump?
  3. sharmstr
  4. Alex Chambers
    As @sharmstr said, but keep mains wiring away from low voltage stuff. I suspend my router cable above the machine.
  5. jeffmorris
    jeffmorris Journeyman
    How do you suspend the router cable/cord over the machine? I suspend the vacuum hose over the machine using a spring.
  6. sharmstr
    I have a 20x20 extrusion bolted to the X gantry plate. Here's an old pic when I had a piece of wood instead
  7. Alex Chambers
    I clamped a piece of 2" x 1" to the side of my bench, screwed a large cup hook into the top and hung my router cable from that. Made sure I had enough slack to reach every corner of the machine.
    Cutting going off path.
    #7 Alex Chambers, Nov 16, 2019
  8. Charles Roseberry
    Thanks for the replies. Yes I do need to get a drag chain for sure. I was hoping that someone came up with something where I didn't have to suspend the power from the router like that. Separating it for interference is also a good thought. I guess I'll have to look up some drag chain configurations. I've never added one. So, guess I need one for both axis'.
  9. sharmstr
    Watch some of the openbuilds assembly videos. You'll see how they attach to the x and y gantries.
    I would advise against putting your router cable in a chain. You'll regret it the first time you need to install new motor brushes.
  10. Charles Roseberry
    Yep , understood. I have my Pro V Controller mounted to the back extrusions of my machine. I'm wondering if I need to change that. But I havent seen many mounted in the photos here.
  11. sharmstr
  12. Colin Mccourt
    Colin Mccourt Journeyman
  13. Giarc
    My CNC router is under a ceiling outlet, I have the power cord plugged in above. It is never in my way and easily moves to all corners of the work area. My vacuum hose hangs down from the same location and air compressor hose is in a slightly further back location. None are ever in my way. This keeps the high voltage and static producing things away from my other wiring.
    Air hose vacuum hose and power suspended:
    Looking down from ceiling:
  14. Charles Roseberry
    I like the idea of an overhead outlet. I may have to consider that. I dont like the outlet sitting way behind a machine like mine is.
    Your knowledge and help is indispensable fellas, thanks very much.
