problem files
Discussion in 'CNC Mills/Routers' started by tazma, May 31, 2018.
  1. tazma
    tazma New
    hello and excuse me if it is not possible what I am going to comment download the files of the opening for OpenBuilds OX cnc to be able to cut myself with my cnc and mount an OpenBuilds OX the problem is that the aspire does not generate well the code for the cut
    How can I generate the code g of the files to make my pieces myself?
    Thank you
    The original designs were all done in Sketchup and the Gcode generated using the SketchUcam plugin for Sketchup.
    So I suggest getting Sketchup Make 2016 and using that to generate the gcode.
    Why 'Sketchup Make 2016' ?
    Because 2017 requires fancy graphics hardware and does not run everywhere and in 2018 the free Make version was removed.
    SketchUp Make 2016 : Download Links
    GrayUK likes this.
  3. David the swarfer
    GrayUK and tazma like this.
