OpenBuilds WorkBee 1510
Discussion in 'CNC Mills/Routers' started by Mark Carew, Jun 15, 2018.
  1. Mark Carew
    Mark Carew published a new build:
  2. sharmstr
    Can you clarify the max material thickness? On the build page, it states 3" (Workable Material Depth 3" (86mm), but in the build video he says 1-3/4"
  3. gibson
    gibson Well-Known
    hello were did u get your belt tensioners from cant find them trying to beef up my ox build of yours ...
  4. TrishC
    TrishC OpenBuilds Team
    Hello gibson. They should be available in the Part Store shortly. :thumbsup:
    gibson likes this.
  5. gibson
    gibson Well-Known
    hi iam looking for somthing to do creatively on my cnc were do i get the plate dxf files to run this ... or PDF print outs ...
  6. JustinTime
    JustinTime Journeyman
    gibson, did you look under the 'Files and Drawings' tab at the top of the page?
  7. gibson
    gibson Well-Known
    i got them ty ... I`am useing fusion 360 as my cad and cam software could u help me with setting them up so i can machine them ...
  8. JustinTime
    Read this. It will help you with your task.
  9. sharmstr
  10. sharmstr
  11. MaryD
    MaryD OpenBuilds Team
    Actually the video is correct @ 1 3/4" , the build page graphic is being updated for all WorkBees in the next hour or so.
  12. sharmstr
    So, its due to the spoiler board beam height? Can I use 20x60 instead of the 20x80?
    Also, check out the other possible mistakes I've found:
    - The option details list 3 motors, not 4.
    - The parts list shows the spoiler board beams to be 20x40, not 20x80 as shown in the video
    - Machine accuracy in your graphic is wrong for the 1510
  13. gibson
    gibson Well-Known
    thank you very much will give it a go later awsome ...
  14. Mark Carew
    Thank you for the feedback we are working to correct these now. :thumbsup:
    Right you could lower it and gain more depth. We put it up high make this large machine as stout as possible.
  15. sharmstr
    Will you guys be doing a wiring video? Or is there wiring doc somewhere that I missed?
    Jesse Mccabe likes this.
  16. Serge E.
    Serge E. Journeyman
    Great to see all the new bundles. So tempting, with the free shipping and all ... Campers will remind me it will soon be Christmas in July. ;)
    Time to do some long overdue upgrades to my aging myOX ...
    GrayUK and Mark Carew like this.
  17. Mark Carew
    Hi sharmstr we are working on a few up and coming wiring videos, that will be super helpful and we started with the OpenBuilds WorkBee 1510 as its the largest.
  18. Mark Carew
    Hey guys just a heads up. We updated the build with an easier to understand xPRO controller diagram in tha main build page that should help to see how to easily wire up the machine to the xPRO controllers.
    Hope this helps.
  19. drcyberg
    drcyberg New
    Hello everyone!
    I like build work area 1000x2000, because only give this size (steel, aluminium). Possible modify in the Workbee cnc items and great work machine? Or need more any componens?
    Big thanks!
    Regards!
  20. Mark Carew
    Hello @drcyberg
    Yes you can modify it, thats the beauty of the OpenBuilds system.
    To make it larger you would need to connect the C-Beam together.
  21. sharmstr
    I'm in the middle of assembly now but found an issue. In the build video, you need 4ea. 27mm screws for the idler wheels on the y axis (2 each side), then 6ea. 27mm screws for the wheels on the x carriage assembly. My kit only came with 6ea. 27mm screws total. It also states 6 on the parts list that was included in my shipment and the parts list that was included with my missing items shipment. The parts list on this thread says 10. I'm fairly confident that it should be 10 and I need 4 more.
  22. TrishC
    Hello @sharmstr You are correct there should be 4 more 27mm screws. The Part Store Team has been reaching out to everyone that has the OpenBuilds WorkBee 1510 shipped to them will be receiving these soon. Thank you for your feedback and understanding.
  23. sharmstr
    No problem. There's a bunch of parts on these things so its to be expected initially. I'll probably pick the screws up at the hardware store.
    Do you know what size the set screw on the timing pulleys are? One of my set screws is missing the hex hole so I can screw it in.
  24. Mark Carew
    :thumbsup:
    The set screws on the timing pulleys are M3 and a 6mm length would work perfect
  25. JustinTime
    I don't like to use the set screws that come with these pulleys. I replace them with 3m socket screws. These screws use a bigger Alan key and are less likely to strip the 'hole' as the set screws do. AND...in emergency a plier will do the work on them (if you don't remember where you put the Alan key :D)
    Mark Carew and sharmstr like this.
  26. sharmstr
    Great idea. I was thinking this AM that it might be hard to find a set screw that size at my local HW store. I know they have that size in a socket head. Thanks!
  27. sharmstr
  28. TrishC
    As this is meant to be more of a mechanical bundle allowing builders to customize the system, the Limit Switches are available in the Part Store separately.
  29. sharmstr
    I see that. For us noobs it would be nice to note that on the product page. I'm guessing I need 3 but do I need them with the mounting brackets? What else do I need to get this thing working that's not already listed on product page?
    #29 sharmstr, Jun 29, 2018
  30. TrishC
    Thank you for the feedback we will be sure to add this this information. :thumbsup:
    The plan is to have a complete wiring video available to accompany the mechanical Build video as soon as possible to help out those who may have questions wiring up their drivers to their machines. These things take time and although we will not be able to cover all the possible electronics/software configurations we are confident that we can get the general idea out to help point in the right direction.
    To answer your question about how many to use, it is usually 3 to use as homing the 3 axis and they are optional as the machine will function just fine without them.
    So really the only thing you really need is to cut a spoiler board and whip up a way to mount your diver card with some wire management and you should be good.
