OpenBuilds Sphinx 55
Discussion in 'CNC Mills/Routers' started by Mark Carew, Jun 15, 2018.
  1. Mark Carew
  2. DA98520
    DA98520 New
    On the original design, the x-axis rail needed to be an extra 3mm wider then the outer edge of the base assembly. Was this taken into consideration on this bundle? I havent had time to fully look at the dimensions of rails cut.
  3. Mark Carew
    We did our best to ensure that this version is as modular as possible and in doing so made sure that the x axis rail could be extended or shorted along it length creating a machine that can grow according to the users needs. So yes its working great, and in fact we have had one of the early betas in the wild for some time with Team member and Project Maker @Ariel Yahni making great Projects.
    Ariel Yahni and GrayUK like this.
  4. Michael.M
    Michael.M Veteran
    This is very cool Mark!
    Kyo and Mark Carew like this.
  5. Mark Carew
    Thanks brother! :thumbsup: but props go out to you guys in the community for refining these designs to awesomeness, the original designers and of course the whole OpenBuilds Team because they were are amazing in coming together to make this happen.
    We are so happy to finally be able to offer a group of proper cartesian style router systems, its always been something that we have wanted to do and it's great to be moving forward in this direction.
    Mark
    Kyo and GrayUK like this.
  6. Kyo
    Kyo Veteran
    The actual length is not that critical. The extra 3mm comes from the 1.5mm on each side the plates are away from the face of the y-axis c-beam. On the original build the 3mm longer rail allowed the y-axis rails to sit flush with the outside edge of the base frame for easy squaring of the machine. The 3mm can also be handled by insetting the y-axis rails 1.5mm for a total of 3mm. If you take a look at Marks Sketchup model he shows the inset y-axis rail option and my original Sketchup model shows the 503mm long x-axis c-beam. Both options work well.
    With the y-axis rails flush on the base frame and x-axis rail length equal to the base width, the plates are forced out of square like so /___\ causing inaccuracy and undue wear and tear on bearings, wheels, nut block, lead screw ect. The Openbuilds v-slot / c-beam systems are very modular and as long as the proper care is taken during assembly to ensure everything is square and parallel you can make the rails any length you need. :thumbsup:
  7. jeffmorris
    jeffmorris Journeyman
    Will the SPHINX end plates be made available separately so that I can mount them on my machine?
  8. NeeqOne
    NeeqOne Well-Known
    Mark mentioned in one thread that you will need to contact the folks at the store for information on this.
    #8 NeeqOne, Jun 19, 2018
  9. MaryD
    MaryD OpenBuilds Team
  10. Comedie
    Comedie New
    Interesting that didn't go with the 2" taller and double nut version of the plates. Any reason why?
    Guess I will have to pay attention to when openbuild sales happen now. Was contemplating cobbling one of these together.With a bundle now available, price is becoming my only point of resistance.
  11. Mark Carew
    Hello @Comedie
    @Kyo and I talked about this, and from what we gathered from the taller builds out there is that deflection seemed to be an issue with the 2" taller plates. We wanted to maintain the low profile stout nature of the original design so we settled there. On the nut blocks the single anti backlash does just fine on its own so we saw no need for the extra cost there.
  12. Mark Carew
    Hey guys just a heads up. We updated the build with an easier to understand xPRO controller diagram in tha main build page that should help to see how to easily wire up the machine to the xPRO controllers.
    Hope this helps.
  13. Mark Carew
    Update on the Sphinx 55 Build. The new wiring and software video is up so follow along with this simple Build Video and get your Sphinx 55 Wired up and Running!
    This video covers all the bases from the limit switches to the drag chains, the driver board OpenCase mounting plates and the spindle LED ring!
    You can grab the wiring kit in and check the video the Part Store - Wiring Kit OpenBuilds Sphinx 55
    Kyo and Michael.M like this.
  14. Kevon Ritter
    Kevon Ritter Veteran
    I just saw the wiring video. The limit switch placement is killing a lot of travel. I made my own limit switch mounting plates, but you should still be able to rotate the included plates by 90. That's about an inch (25mm) of extra travel. The Z kills a lot too.
    Include a tiny offset plate and you can use every mm of available length. I don't have a clear picture (I can grab one later), but with the little offset plate and a simple standoff, you can put the limit switch on the side instead of directly in the travel. That get's you all the way up to the grub screw on the lead screw lock collar.
    Kyo, MaryD and Mark Carew like this.
  15. Mark Carew
    Good idea @Kevon Ritter thanks for sharing. This kind of collaboration is what makes Openbuilds a such a fun place to hang and learn!
    This would make a great Parts Resource for the community., If your able to share the file that would be great!
    Thanks again
    Mark
  16. Kevon Ritter
    I'll put something together when I get home from work.
    MaryD likes this.
  17. Kevon Ritter
  18. Mark Carew
    Thanks!
  19. ashish B
    ashish B New
    In the build, am I only seeing one limit switch per axis ? should there be not two for each direction ?
  20. JustinTime
    JustinTime Journeyman
    It's a good practice to have two limit switches on each axis, one on each end, but many builder leave one out and keep only one, for the homing. I have two switches per axis on my machine. AND...two emergency stop switches. :D
  21. ashish B
    ashish B New
    that is what I am planning to do.
  22. David Bunch
    David Bunch Veteran
    How much does the Sphinx 55 weigh? I see on page 4 of Kyo's C-Beam Sphinx that his weighs about 70lbs. Is that about the weight of this machine? I know the weight can vary a bit depending on the optional hardware you have on it, but it would be nice to see an approximate weight listed in the specs for each of the machines.
  23. TrishC
    TrishC OpenBuilds Team
    Hello David. The Sphinx 55 shipping weight is approx. 45 Lbs. for the Bundle, Wiring Kit, Power Supply Bundle and Stepper Motors. Thanks for the feedback on the weights. We will look into getting this information added.
  24. David Bunch
    David Bunch Veteran
    Cool, thanks for the info. I like that weight a lot better than the 70lbs I was thinking it might be.
  25. Giarc
    It could well be 70 pounds after adding the spoilboard. MDF is heavy.
    Kyo likes this.
  26. Kyo
    Kyo Veteran
    I think most Sphinx builds will come in under the weight of my original build. When I measured the weight of my machine. I had a 1/2" cast mic 6 tooling plate as the base bed of the machine topped with two additional 1/2" thick MDF spoiler boards to reduce the Z-axis. Those three plates added a fair bit of weight to the machine.
  27. TrishC
    The shipping weight listed didn't include the Spindle either which will also add a few pounds :)
  28. David Bunch
    David Bunch Veteran
    After asking that question, I remembered that plate you had put in the bottom & figured that was the extra weight. I have some MDF board, so have an idea of how much extra that weighs. Thanks for the info.
  29. 3DStyle
    3DStyle New
    Hi guys,
    I'm just about to receive all the hardware and electronics parts for my Sphinx 55 build. I would first like to thanks for the design of this machine!
    I didn't buy the Sphinx plates set yet because I waited for all the other parts to arrive with peace from China, and now I'm ready to purchase the plates.
    Will you recommend buying the OpenBuilds plates version or Kyo's version? What are the pros and cons of each?
    I also saw that the OpenBuilds ones are rated as version 7, what are the main differences from Kyo's version?
  30. Kyo
    Kyo Veteran
    @3DStyle ,
    I do not sale any plates, Chris and Openbuilds both provide a quality plate set. I can not recommend any of the plate sets from aliexpress. The OpenBuilds Sphinx plate set is the cheaper option and comes with quality support from OpenBuilds. This plate set has a couple design revisions to assist with manufacturing no changes that should affect your build.
