Openbuilds Control Post Processor For Rotary Toolpaths
Discussion in 'OpenBuilds Forum Help' started by Jkelly0325, Mar 27, 2024.
  1. Jkelly0325
    Can Openbuilds Control be used for rotary toolpaths. I'm converting from Millrights UGA post processor to Openbuilds Control. First attempt gantry moved along the y-axis rather than rotating the chuck.
    CONTROL is just a host - just sends your GCODE along to the controller
    You need a CAM (Fusion or Vectric) to create your gcode.
  3. Jkelly0325
    Using v-carve Pro to create the g-code. Post processor is G-CODE WrapY2A(mm)(*.TAP)
  4. David the swarfer
    have you got the rotary connected to the Y axis on the Blackbox?
    soudns like you have X connected instead.
  5. Jkelly0325
    I'm not using a Blackbox, just the openbuilds control software.
  6. Alex Chambers
    Why are you using a *.TAP post processor? I very much doubt that it will be compatible with grbl. What controller set up do you have?
  7. David the swarfer
    so what have you got, and how it is all connected?
  8. Jkelly0325
    Using G-CODE WrapY2A(mm)(*.TAP) with Millright UGS for rotary operations without issue. I'm using the Millright controller for the MEGA V XL, which has a 4th axis 4 pin mike connector that goes from the controller to the rotary. Don't need to plug or unplug anything to go from standard Y-axis to 4th-axis operation as long as I use a the G-CODE WrapY2A(mm)(*.TAP) post processor.
  9. David the swarfer
    so you have an actual 4th axis that is referenced by the controller as the A axis and NOT swapping plugs to run the rotary off the Y axis, right?
  10. Jkelly0325
    That is correct.
  11. Peter Van Der Walt
  12. Jkelly0325
    Much appreciated, I have DeskProto on my machine so I'll give it a try.
  13. dwight williams jr
    So are you using the black box with deskproto for rotary cutting? If so im curious on how you do this.
  14. Peter Van Der Walt
    Yes we do. Nothing really difficult about it - try it and shout when you get stuck
  15. dwight williams jr
    I have purchased it and love how easy it is to setup the stl files. I just can't figure out how to get it to use x as the rotary axis and not A or B and if I turn off both it shows as it won't mill the underside.
  16. Peter Van Der Walt
    The BlackBox X32 has proper A-axis support. Thats where we use it, also see post #9 and #10 above (also A axis)
  17. dwight williams jr
    Thanks for the info. Doing a little more research took me to this post Blackbox X32 Rotary 4th Axis Wiring
    which you made and got me on the right path and I got it all setup and working.
