negative values after homing
Discussion in 'Controller Boards' started by scancool, Apr 27, 2019.
Tags:
  1. scancool
    scancool New
    I'm new to grbl and I'm trying to understand where this negative values come from after homing.
  2. sharmstr
    The coordinates being shown is your work coordinates (stock). When you home, you are setting your machine coordinates. So, based on the picture, you work origin is X-198 Y-206 Z2 from your home position.
  3. scancool
    scancool New
    Thanks, good to know Sharmstr, do you know where that configuration is located?
  4. sharmstr
  6. David the swarfer
    yeah, forget the negative numbers.
    jog to where you need the work o,o,o origin to be, hit the 'set zero' buttons and cut your job.
    assuming your work origin in bottom left corner then all the gcode will be positive except Z, Z going negative will indicate it is cutting material. (more detail: XY zero is at bottom left, Z zero is at the top of the material).
    if you make your work origin in the middle of the part (in your CAD/CAM software) then some of hte Gcode will be negative and some positive.
    so what? doesn't matter, GRBL will do the right thing so long as you set the work 0,0,0 at the right place on the raw material. you never need to think about the negative machine coordinates because you can just jog to where you need to be and set Work zeros.
    GrayUK likes this.
