Miter Saw Stop Block
Discussion in 'Other Builds' started by rkugler, Feb 14, 2018.
  1. rkugler
    rkugler New
    rkugler published a new build:
  2. JustinTime
    JustinTime Veteran
    The way I see it you will need to zero the stop every time you turn on the machine since it will not know where it is. If the machine is on all day it's not a big problem since it has to be zeroed only once a day.
    You will need a positive lock on the stop or it will move every time you bump against it. While the motors are powerful and should resist moving while under power it still may move a fraction.
  3. rkugler
    rkugler New
    Hi Justin,
    Ohhhh, good point about zeroing. Could there be a shut down procedure where the stop goes 'home' upon power down, then knows where it is at start up? Hadn't considered having to lock the stop..... but I see how it could be bumped out. Is there a way to lock a belt drive like a shaft lock on a screw?
    All good points, thanks so much!
    Roger
  4. JustinTime
    JustinTime Veteran
    The belt can not be locked in any meaningful way. One way to solve the locking is to use a thin threaded rod, like #6x32. It has teeth every 1/32". Run it the whole length of the side. Have a small #6 rod, maybe 1", engage into the long run when you have reached the stop position. It will have to be done with a servo or with an electromagnet and spring. You'll have to write the code for it to engage and disengage when needed.
  5. rkugler
    rkugler New
    Ya, that would work. The miter stop I'm using now uses this technique. OK, lots to think about. Thanks!
  6. R. D. Childers
    What is the status of this project?
    #6 R. D. Childers, Apr 21, 2019
  7. pauna
    pauna New
    You continue your project "Mit Saw Stop Block"
    I also want to get closer to doing something like "Table Saw Fence Control"
    I find programming difficult
  8. Rick 2.0
    You might take a look at this project: Cut To Length Machine
  9. pauna
    pauna New
    thanks. Maybe the discussion will resume there as well
