Led lights on xPRO v4 controller
Discussion in 'General Talk' started by Les Adams, Apr 18, 2019.
  1. Les Adams
    Les Adams New
    Can anyone explain the leds on what color they should be when running and when not running
  2. sharmstr
  3. bubba
    bubba New
    Per Mike from Sparks Concepts:
    >>The LEDs are there to show motor power for each coil (red is coil A and green is coil B) - all this means is you have power going to the motor. On startup previously your B coil was energized, now your A coil is. The thing to note, with micro-stepping enabled there are a couple microsteps where both LEDs will be very dim but light up when the motor moves to the next step, just FYI.
    Les Adams likes this.
  4. Les Adams
    Les Adams New
    Thanks Mark Didnt know if there needed to be a pot. adjustment.
    ark
  5. Les Adams
    Les Adams New
    Thanks Mark. Didnt know if it had something to do with the Pot . adjustments
