Laser Cutter/Engraver OptLaser 6W with Z-axis
Discussion in 'Laser Cutters' started by RobSaunders, Dec 8, 2017.
  1. RobSaunders
    RobSaunders published a new build:
  2. Anthony Bolgar
    Anthony Bolgar Journeyman
    Nice build. On my diode laser I also made an adjustable Z axis, makes focusing so much easier than propping the work piece on various things to get to the proper focal length.
  3. RobSaunders
    Thanks!
  4. Mark Carew
    Great Build Rob, love the z axis idea! Thanks for sharing brother :thumbsup:
  5. RobSaunders
    Thanks Mark. I ended up using LaserWeb4 and when I realized I could have control over the z-axis during a job, I had to add it.
    MaryD likes this.
  6. Hankster
    Hankster New
    Nice job Rob ! I hope to do something like this soon. I would like to be able to cut the three ply 5mm plywood you get at the box stores (HomeDepo, Lowes). By chance, have you tryed cutting plywood with your 6 watt Laser ?
  7. RobSaunders
    Hi. For plywood I've only cut 1/16 and 1/32 stuff for aircraft. For a test I did cut thru a 1/2" piece of poplar.
  8. JustinTime
    JustinTime Journeyman
    You cut thru a 1/2" material? WOW, that's great news. It will open up many possibilities. It may eliminate the need for CO2 laser, if time is not of an essence.
  9. RobSaunders
    Yes but it's definitely not worth the time. I'm still trying to get a feel for what capabilities I have :)
  10. Steven Yampolsky
    This is awesome! I'm also building ACRO to cut model airplane parts as well! I'm planning to use mostly 1/8 and 3/32 balsa and 1/64 ply and 1/8 lite ply. I'm a total newbie and need all the help I can get! The fact that you are using this laser for the same thing makes it easier to comprehend things.
    My question is: why do you need a z-axis if you are cutting sheets of balsa? Is it needed if I'm cutting multiple thicknesses at once(1/4" for flaps, 1/8 for ribs, etc)?
  11. dragonfire81m
    most cases u have to make multiple passes to cut your material so the focal point changes very or very other pass
  12. Steven Yampolsky
    Makes sense! Any chance you can share details of construction? 3d part files, components used(where to get them), how to prepare a cut file for multi pass.
  13. magma1974
    magma1974 New
    Any chance to share STL or model files .This is great idea
  14. syl
    syl New
    Do you mind sharing your laserweb setup?
  15. FireFlite82
    Hi! Nice build. I too am into RC flying and hence the reason I landed on this website. I know diddly about laser CNC lazer cutters. I was hoping you could share what resources you used to build your setup? It seems that your build would be ideal for what I'm wanting to do. Any advice would be awesome!
