K40 Laser Build (Major Changes)
Discussion in 'Laser Cutters' started by Superslinky, Nov 8, 2017.
  1. Superslinky
  2. Ariel Yahni
    Ariel Yahni OpenBuilds Team
    Very interesting build. What you actual max cut size?
  3. Superslinky
    I don't know yet. I'm going to start firing things up this weekend. I'm not sure if the laser will loose so much power that it won't cut in the furthest corners or not. During the mirror alignment process I could easily pierce a hole at all 4 corners but we'll see.
  4. Ariel Yahni
    You should not loose any power if you have a good alignment. :)
  5. ErikE
    ErikE New
    Hi!, I can chime in a little here. I have replaced the standard controller to a Cohesion3D board (direct drop in and Smoothie compatible). There are various software solutions that work with it eg. Laserweb. You could keep the standard board (if it's a m2nano) and use K40 Whisperer . So.. there are choices :) and it's easy..
    Superslinky and Retrosmith like this.
  6. greengoatman
    Can you post a picture or explanation of how you accomplished the z axis?
  7. jwarren
    jwarren New
    Can you upload the stl's for your printed parts?
  8. Superslinky
    I use a smoothieware controller. It works really well. The software I use is Adobe cs straight to laserweb. Look them both up. They are the best open source combination out there.
    DA98520 likes this.
  9. Superslinky
    I've considered this idea as well. There are a few issues though. As far as mounting the tube on the spindle, you'd end up with a large mass that would be difficult to keep stable. The tube is 700 mm long so all of that would be moving around. But as far as gutting the machine, that is what I did first.
  10. Superslinky
    Here's a closeup picture but most of this is documented in my 3d model.
  11. Dave Crevier
    This is pretty close to what I was planning on doing. The thing I was wondering about is are you not scared about the melamine catching fire?....I was thinking about covering the inside with like 24ga. Sheet metal. Have you've had any issues?
