Is "Report in Inches" disabled?
Discussion in 'Interfaces' started by jda70az, Mar 16, 2021.
  1. jda70az
    jda70az Well-Known
    Every time I try and set this in OB software or even load up file containing all the GRBL settings
    it always reverts back to ZERO.
    What gives?
  2. sharmstr
    No, its not disabled. If you have enabled it and look at the console log it will show that $13=1. I think its just bug in the UI. Might have something to do with why that select looks different than the others as well. Peter will know.
    Peter, if you inspect the select, it does show value=1. UI just isnt displaying it correctly.
    #2 sharmstr, Mar 16, 2021
    It should be Disabled, we expect Grbl to report in mm, and handle Inch conversions ourselves. Do not set it to Inch.
  4. jda70az
    jda70az Well-Known
    I'm American I don't use Millimeters.
    Yes, but click the Inch mode tab in CONTROL above the DROs. Leave the one in Grbl Settings alone. Grbl should reports in mm to CONTROL: CONTROL handles the conversion for you.
    PS: Inch mode was the default, if you see mm's you clicked on mm-mode at some point :)
    #5 Peter Van Der Walt, Mar 17, 2021
