Interface issue
Discussion in 'General Talk' started by Luis Barros, Nov 24, 2022.
  1. Luis Barros
    I didn't open a ticket because I believe I missed something on this, when I start a job using the interface and after probing with xyz probe the bit stays too high like kept the zero reading from the top of the probe without deducting the thickness of the probe. I'm using blackbox32, interface and probe xyz from openbuilds.
  2. sharmstr
    Out of curiosity, what does the Z dro read when its done probing?
  3. Luis Barros
    After done probing I get this:
    X -0.02
    Y -0.02
    Z 14.00
    PS Just added pictures of the interface screen
    #3 Luis Barros, Nov 24, 2022
  4. Luis Barros
    Found the problem.....user error!!! I had the steps wrong and I used the wizard to calibrate. Z moved 5 mm when should be 20mm and the other axes moved 67mm when should be 100mm.
  5. sharmstr
    That was going to be my suggestion. Glad you figured it out.
