HandCrafted WorkBee - HCWB
Discussion in 'CNC Mills/Routers' started by joe williams, Aug 14, 2018.
  1. joe williams
    joe williams Well-Known
    joe williams published a new build:
  2. GrayUK
    Wow. :D What a professional looking table. I don't know what country you are in, but in the UK, the materials you used would cost more than the machine. Oak! :jawdrop:
    I can feel you are going to build a great machine, and produce even better projects with it. :thumbsup:
    We all await your progress.
    Gray
    Michael.M likes this.
  3. joe williams
    Hey GrayUK, I'm in Louisiana, USA! Well actually the oak is reclaimed...I payed very little for it!
    I'm looking forward to some progress too!
  4. JustinTime
    JustinTime Journeyman
    Like Gray said, nice table, Joe!
    I would have gone with a 269oz stepper (heck...I did go with the 269oz stepper :D). I know, they are $8 more per stepper but in the long run I think they'll serve you better.
  5. MaryD
    MaryD OpenBuilds Team
    That is a handsome table. Look forward to following your build!
  6. GeoffH
    GeoffH Journeyman
    Nice table Joe! My main recommendation for the Workbee is to see if you can design side plates that will give large Z travel, I think 150mm of travel is good. Look forward to seeing more...
  7. joe williams
    Yeah, thought about that too...I'll try this size first. Plan on using drivers with enough 'muscle' for bigger steppers just in case!
  8. joe williams
    I was thinking about adding a little to the side plates as well as setting the spoiler board low,...good recommendation!
  9. Ryan Lock
    Ryan Lock Veteran
    Wow, looking forward to seeing this! The table looks great :thumbsup:
  10. joe williams
    So the steppers came in. Looks like I've got enough parts gathered to start making the plates!
    GrayUK likes this.
  11. joe williams
    An Arduino Nano might be coming in today:
    and one of these drivers too, the TB6560
    I've ordered only one driver at this point because I may go with all 4 TB6560, or I might save up and buy 4 DQ542MA drivers instead. Can anyone here help me filter thru all the DM542 based drivers available at other retailers and here at Openbuilds?
    Sainsmart ST-DM542:
    Stepperonline DM542T:
    digital-stepper-driver-10-42a-20-50vdc-for-nema-17-23-24-stepper-motor-382-225x225.jpg
    Stepperonline DM542S:
    #11 joe williams, Aug 19, 2018
  12. joe williams
    I'm leaning toward the Arduino Nano/GRBL controller and TB6560 drivers combination that Metalguru has documented so well.(thanks!) It seems simple, reliable and very cost effective. However the DM542 style driver could provide some "future-proofing" for possible stepper upgrades.
    Any opinions?
  13. JustinTime
    I haven't looked into it in a loooong time but I remember that there were issues with the TB6560 and that the successor to it is the TB6600. Look up the 6600 on Aliexpress and/or google the difference between the two.
  14. joe williams
    Do you have a favorite "brand" of TB6600 driver?
  15. JustinTime
    No, not really. Unless, that is, you call Aliexpress a "brand". :ROFL::ROFL:
    joe williams likes this.
  16. GrayUK
    Hi Joe.
    Do check out the max handling of Amps with those Drivers. Make sure they will cope with the demand your motors, and any future motors will make. That is frequently a weakness of the cheaper Drivers on Ebay.
  17. Michael.M
    Michael.M Veteran
    Wow, excellent wood work buddy! I can't wait to see this beauty completed.
  18. joe williams
    Thanks Michael! I'm looking forward to it too! Just got in some more stuff this week and I've been playing around with an Arduino Nano, getting GRBL loaded on it and goofing around with UGS Platform. This came in a couple of days ago, so it will be time to hook up a driver and a stepper soon, and see if I can get them to work! 61BmWa7rGXL._SL1000_.jpg
    #18 joe williams, Aug 25, 2018
  19. joe williams
    Hey Michael, I followed your Sphinx build. I love that solid aluminum bed, (I might be jealous) I see you went with the DQ542MA drivers, I'm trying to talk myself into those as well!
  20. Michael.M
    Michael.M Veteran
    I can only speak for those particular drivers as I have no experience with anything else. With that said, installation was very straight forward and I've had zero problems so far. I think they are necessary for the higher current stepper motors. If you have any questions, feel free contact me.
    MaryD and joe williams like this.
  21. joe williams
    Thanks for everyones input. I ended up getting some DM542 drivers. They just came in. I'll be doing a test setup soon!
    #21 joe williams, Aug 30, 2018
  22. joe williams
    So I've been fiddling around with and old computer case. I've got the power supply, drivers and Arduino nano installed as well as the steppers temporarily connected and tested. So far so good. On to making plates next, or maybe messing around with the base frame.
  23. GrayUK
    That looks neat and tidy Joe. Do keep that air flowing with fans, it's gonna get quite warm in there :thumbsup::thumbsup:
    Do you think they will start producing computer cases for ATX boards as well as CNC drivers and Control boards??? :D
    Could be a secondary market there, the way things are going. :rolleyes:
    I know I've got an old case lined up for the next project. :thumbsup:
  24. joe williams
    I can see it now: "The New Openbuilds Modular Controller/PC Case" !
    Available in 3 fine finishes:
    • Black
    • Gray
    • Camo
    #24 joe williams, Sep 4, 2018
  25. GrayUK
    Don't forget the LIGHTS!!!!!!! :jawdrop::jawdrop::thumbsup::thumbsup:
    You gotta have loads of lights and stuff!! :D:ROFL:
  26. Andreas Bockert
    Andreas Bockert Well-Known
    The only problem I had with the Dm542 from stepperonline was that I had to disable the idle timeout in grbl. It seemed like the drivers needed some time to start up before they were ready to accept steps.
    Good luck and have fun!
  27. joe williams
    Thanks for the tip!
