GCODE to enable/ disable end stops
Discussion in 'General Talk' started by Corey Applegate, Feb 28, 2021.
  1. Corey Applegate
    I have the Xtension Limit Switch but am not ideal with how I configured my electronics. Mostly cause I'm trying to keep my setup mobile and stuffed the Dewalt power in the cable chain.
    I do get sporadic OT faults. I have ran shielded wire and had an perceived improvement, but they still happen. The last one happened with the limit switched disconnected from the Black Box Controller. So the noise is somehow still getting in. Maybe the Steppers?
    Any how is there an enable/ disable gcode?
    I'm going to add shielded power cable in the next few weeks when my Spindle arrives and I increase the size of the cable chain.
    Corey Applegate likes this.
  3. Corey Applegate
    Yes in the configuration, but can I Turn it on/ off in gcode
  4. sharmstr
  5. Corey Applegate
    I tried to put the $21 1 in my gcode.
    So I can't do that? I must just enter the line in the serial console when the program is not running?
    What is the syntax?
  6. sharmstr
  7. sharmstr
    It will do you a ton of good to read the grbl wiki gnea/grbl
  8. Corey Applegate
    On a mobile device it is tough to get a good read. I'll look more when I get to a pc.
