FlashPoint CNC v1: 500mm x 1000mm 3-Axis CNC Router
Discussion in 'CNC Mills/Routers' started by Jay Almers, Jan 10, 2019.
  1. Jay Almers
    Jay Almers published a new build:
    The C-Beam® Gantry Plate shown on the X-axis may not provide sufficient rigidity to prevent flexing of the Z-axis because of its narrow grip. I would suggest using one that grips the outer edges of the C-beam like the XLarge C-Beam Gantry Plate.
  3. arcrunner
    arcrunner Well-Known
    If you use the xlarge c beam plate, you can face the x axis lead screw away from the cutting area
  4. Jay Almers
    Good call. I see your point. I think I will have the same problem with the Z axis. One thing I didn't include on the CAD drawing was I have a 250mm 20x60 V-Slot plate attached to the Z axis cart where the router will be bolted. I was hoping that would provide the rigidity needed. With this being v1, I am sure there will be many "ah-hah" moments.
  5. Jay Almers
    Wouldn't I need two XL Plates? One on the lead screw side with the anti-backlast nut and one on the back....essentially sandwiching the C-Beam?
  6. arcrunner
    Yes, just like the LEAD machine.
  7. GrayUK
    Twist, is the main enemy of the CNC. This is front and back movement from the tip of the cutter, running into the Z-axis, into the X-axis and then the Y-axis. An accumulative event which needs to be stopped, as best can be, at the Z-axis.
  8. Jay Almers
    If I were to purchase C-Beam XL plates, would I need 2 per axis? Or would a set on the X axis be sufficient?
  9. Rick 2.0
    Depends on the weight of the router.
  10. Jay Almers
    I have a Dewalt DW611. Do you think my setup is stout enough if I take shallow passes at slow speeds until I can raise the funds (trying to form non-profit) for the beefier plates?
  11. Jay Almers
    I have modified the XL C-Beam plate and C-Beam end plate to make a single unit for the Y-axis. I am thinking if I cut a set of these out, that will solve some excess parts issues and by mounting a XL C-Beam plate on the backside of the C-Beam to this arm, I should get that rigidity I am looking for. Thoughts?
