Design Question
Discussion in 'General Talk' started by selkov, Feb 28, 2019.
  1. selkov
    selkov New
    So much info on this web yet some basic's I can not find. IE, I am planning a build using c-frame and I will be using the 90 degree plates to join vertical uprights. So I need screws [m5] and tee nuts [m5] but I can not find the thickness of the plate or the well depth for the c-beam so what length screw do I need?
  2. sharmstr
    The thickness of the plate (4mm) is located on the product page. The depth of the c-beam well is 6.1mm
  3. selkov
    selkov New
    I see I wrote 90 degree plate, I was looking actually lookin at the t joining plate, no dimension is given there. I assume there the same though.
    Thanks for the well depth.
  4. sharmstr
    The t joining plate has the thickness listed on the page as well T Joining Plate
  5. sharmstr
    It also says in the description to use 10mm screws. :)
    Mounts easily with 10mm Low Profile M5 Screw (sold separately)
