crypt-cube
Discussion in '3D printers' started by crypt-tek, Mar 12, 2019.
  1. crypt-tek
    crypt-tek New
    crypt-tek published a new build:
  2. Tim Curtis
    Looking good!
  3. Rob Taylor
    Oh, this is nice! What's the performance like? What software chain?
    Got any detail pics of the shoulder bolt system? Did you tap the hardened ballscrews?
  4. crypt-tek
    crypt-tek New
    I will post more pictures soon, undergoing extruder head reconstruction as we speak. Performance is good so far calibration cube 20x20x20 came out at around 20.01 - 20.02 each side as of right now. Upgrading the extruders to 2 Bondtech dual drive extruders because I was having issues with Nylon filaments. The hardened ballscrew on the Z axis is not tapped, it is just rotating on a bearing and thrust bearings with the pulley attached to the shaft via 2 set screws.
  5. shanehooper
    Well done!
