Brand new black box
Discussion in 'Controller Boards' started by Chadfarmer, Jun 3, 2019.
  1. Chadfarmer
    Just got put together watching the video took old controller out and connected this controller cant connect in openbuilds software or other
    15596066359216561883263833605033.jpg 15596066628394703201932243644929.jpg 15596066359216561883263833605033.jpg 15596066628394703201932243644929.jpg 24 v power supply a 1510 workbee. Tryed 3 different cables and i have just pulled off different controller that was working.
    Power white goes 24v black goes to grd
  2. sharmstr
    sharmstr Master
  3. Chadfarmer
    yep same thing
  4. Chadfarmer
    just hooked iot up and when I link all cables up the switches now say usb not recognized
    did with everything unhooked at first then hooked up just incase after powering down
  5. Chadfarmer
    ok I think that my switch wiring was wrong it changed it nothing plugged in doesn't connect what it supposed to say it is in device manager windows 10
  6. Chadfarmer
    Here is what is shows
  7. sharmstr
    sharmstr Master
    In the pictures above, do you have your usb cable plugged into the box and the computer? The usb icon should light up when it is.
    Device mgr looks good. What's listed in com ports?
  8. Chadfarmer
    Usb and power only hooked up
    Ill get pic of com ports for u
  9. Chadfarmer
    When u plug usb in there is a light at top on by stepper and the usb. on the side with reset comes on for a second.
  10. Chadfarmer
    Here light that stays on
  11. Peter Van Der Walt
    Staff Member Moderator Project Maker Builder Resident Builder
    Its hard to confirm in the pictures, and yes I know you have confirmed some of these but just for sake of a systematic approach, tick of these checks, one by one, in order:
    1. Unplug everything from the BlackBox
    2. Confirm that PORTS under device manager is indeed EMPTY (That COM5 isnt something else thats plugged into PC)
    3. Connect JUST USB (no power, no motors, no limits, no tools, etc... JUST USB) - wait for PC to Enumate and show up as a USB Serial Port in Device Manager under Ports
    4. Open OpenBuildsCONTROL
    5. Click CONNECT: IF it still fails, go to the Serial Tab and grab a screenshot. PS Please don't use a camera pointed at your PC Screen, it makes for hard to read screenshots. Use the built in tools on Windows: SNIPPING TOOL , save and upload that instead.
    6. You can also try just reflashing Grbl: in OpenBuildsCONTROL, go to "Wizards and Tools" at the top, then go to Grbl Flashing Tool on the menu
    6.1 . Set it up like this: (Your COM port number will be different...)
    6.2 Click Flash. Keep an eye on the Serial Log tab for details if it had success or failed.
  12. Chadfarmer
    I think i did all that but will do again 4 hours last night
  13. Peter Van Der Walt
    Well, all in all those steps is about 5 minutes. Just keep your focus and work them one by one, in order
  14. Chadfarmer
    4 hours of searching forums to find out if anything else. I figured would work ouf of the box put the old controller back on so i could cut again.
  15. Peter Van Der Walt
    Well, lets see the results of the tests. NB screenshots of that Serial Log tab, there it tells you everthing it does
  16. Chadfarmer
    every step worked
  17. Chadfarmer
    Also the flash failed also. As u can see
  18. Chadfarmer
    Detecting a change is unpluging andpluging in usb
  19. Peter Van Der Walt
  20. Chadfarmer
    Ok got new box and after turning on my black box axises lock then i move just a little and i have red lights on all axis but z something new.
  21. Chadfarmer
    Turn off power and my axis work correctly then 30 seconds same thing
  22. sharmstr
    sharmstr Master
    Try adusting the current via the trim pots
  23. Chadfarmer
    Full power and low power the same thing
  24. Chadfarmer
    My z wont even move up now. Put my old controller back on works fine
  25. Peter Van Der Walt
    If you have limits and its wired or configured wrong it may prevent moving in one direction
  26. Chadfarmer
    $20
    $21 disable both
  27. Chadfarmer
    Is there a number to call!
  28. Chadfarmer
    I am not getting it to stop on the switches either
    Maybe some help here need to get this rolling defective part now i have red lights
    About ready to just send it back
  29. Chadfarmer
    Played with the voltage and i think i got the red lights out. Atleast for 10 mins ok 1510 normal limit switches i did like the manual about said but just broke a couple can any verify the color. I have black going to no and red c
  30. Alex Chambers
    The wiring to the switches doesn't matter - they will work properly whichever way they are wired.
