Bolt Torque with an Epoxy Insert
Discussion in 'CNC Mills/Routers' started by Project Hopeless, Apr 10, 2020.
  1. Project Hopeless
    I have M6 x 20 threaded inserts epoxied cross grain in Baltic Birch plywood. Tightening these bolts down has me nervous.
    https://openbuilds.com/attachments/gantry-setup-rails-and-ballscrew-jpg.45352/
    I can find some tables on pull out force for the inserts, but none that relate to a torque spec for the bolt in the insert.
    Does a table exist that gives a bolts torque spec for its matching insert in wood? For the plywood builder out there what have you used as a guide?
