Blackbox
Discussion in 'CNC Mills/Routers' started by Eric Savard, Oct 14, 2019.
  1. Eric Savard
    Im using work bee 1510 and wanna buy Vectric but blackbox is not in post processor choice !
    so what is the one i should choose to match with blackbox ?
    Thx for help
  2. Matthew Bates
    Matthew Bates OpenBuilds Team
    Hi Eric,
    I have uploaded a file to display the post processor you will use with the BlackBox Motion Control System. You will select (G-Code mm).
  3. Eric Savard
    Thx alot !
    Matthew Bates likes this.
  4. Matthew Bates
    You're most welcome. :thumbsup:
  5. Eric Savard
    i tried it but said invalid code in g-code file
  6. Matthew Bates
    Are you using OpenBuilds Control Software? If so go to the G Code editor tab and delete the first line (should be Tap) after that your job should run perfectly.
  7. sharmstr
    I've started a thread on how to modify the post processor so you dont have to edit every file:
    VCarve OB friendly post processor: VCarve GRBL Post Processor Mods
