blackbox just grinding and making noise
Discussion in 'Controller Boards' started by doublepanther, May 14, 2019.
  1. doublepanther
    hello everyone! i got a new black box. built it, hooked it up, openbuilds control, software seems fine, but when i turn it on the steppers have a loud hum and vibrate. if i try to jog it makes a lot of noise but no movement
  2. sharmstr
    Sounds like a wiring issue. Double check your pairs.
  3. sharmstr
    Here's a good explanation on how to check your pairs from @Metalguru C-Beam Machine XLarge
    If you're certain that the wiring is correct, please provide us with more information. What motors?
  4. doublepanther
    had to learn some chinese color characters, because of the stepper choices. it was the wiring. they used the same colors but exactly backwards to openbuilds steppers. running good now. thank you guys for fast response! on the bright side now i know some chinese lol
