Blackbox cannot connect after hard limit alarm
Discussion in 'General Talk' started by Tom Bellfoy, Mar 7, 2021.
  1. Tom Bellfoy
    I was setting up a new location for my upper Z hard limit and the hard limit must have triggered, then I was disconnected from the blackbox, now it cannot connect to blackbox. what gives ?
    see my screenshot below
    16:24:51] [ 3D Viewer ] WebGL Support found! success: this application will work optimally on this device!
    [16:24:51] [ websocket ] Bidirectional Websocket Interface Started Succesfully
    [16:24:52] [ update ] Checking for Updates
    [16:24:55] [ update ] You are already running OpenBuilds CONTROL 1.0.289
    [16:24:59] [ connect ] PORT INFO: Port is now open: COM3 - Attempting to detect Firmware
    [16:24:59] [ connect ] Checking for firmware on COM3
    [16:24:59] [ connect ] Detecting Firmware: Method 1 (Autoreset)
    [16:25:00] [ connect ] Detecting Firmware: Method 2 (Ctrl+X)
    [16:25:01] [ connect ] Detecting Firmware: Method 3 (others that are not supported)
    [16:25:03] [ connect ] ERROR!: No supported firmware detected - See docs:blackbox:faq-usb-connection-failed [OpenBuilds Documentation] for more details. Closing port COM3
    [16:25:03] [ disconnect ] PORT INFO: Port closed
    [16:27:02] [ usb ports ] Detected a change in available ports: [ No devices connected ]
    [16:27:15] [ usb ports ] Detected a change in available ports: [COM3]
    [16:27:28] [ connect ] PORT INFO: Port is now open: COM3 - Attempting to detect Firmware
    [16:27:28] [ connect ] Checking for firmware on COM3
    [16:27:28] [ connect ] Detecting Firmware: Method 1 (Autoreset)
    [16:27:29] [ connect ] Detecting Firmware: Method 2 (Ctrl+X)
    [16:27:30] [ connect ] Detecting Firmware: Method 3 (others that are not supported)
    [16:27:32] [ connect ] ERROR!: No supported firmware detected - See docs:blackbox:faq-usb-connection-failed [OpenBuilds Documentation] for more details. Closing port COM3
    [16:27:33] [ disconnect ] PORT INFO: Port closed
    [16:27:52] [ usb ports ] Detected a change in available ports: [ No devices connected ]
    [16:27:55] [ usb ports ] Detected a change in available ports: [COM3]
    [16:28:00] [ connect ] PORT INFO: Port is now open: COM3 - Attempting to detect Firmware
    [16:28:00] [ connect ] Checking for firmware on COM3
    [16:28:00] [ connect ] Detecting Firmware: Method 1 (Autoreset)
    [16:28:01] [ connect ] Detecting Firmware: Method 2 (Ctrl+X)
    [16:28:02] [ connect ] Detecting Firmware: Method 3 (others that are not supported)
    [16:28:04] [ connect ] ERROR!: No supported firmware detected - See docs:blackbox:faq-usb-connection-failed [OpenBuilds Documentation] for more details. Closing port COM3
    [16:28:04] [ disconnect ] PORT INFO: Port closed
    [16:28:19] [ connect ] PORT INFO: Port is now open: COM3 - Attempting to detect Firmware
    [16:28:19] [ connect ] Checking for firmware on COM3
    [16:28:19] [ connect ] Detecting Firmware: Method 1 (Autoreset)
    [16:28:20] [ connect ] Detecting Firmware: Method 2 (Ctrl+X)
    [16:28:21] [ connect ] Detecting Firmware: Method 3 (others that are not supported)
    [16:28:23] [ connect ] ERROR!: No supported firmware detected - See docs:blackbox:faq-usb-connection-failed [OpenBuilds Documentation] for more details. Closing port COM3
    [16:28:23] [ disconnect ] PORT INFO: Port closed
    [16:29:32] [ usb ports ] Detected a change in available ports: [ No devices connected ]
    [16:29:42] [ websocket ] Disconnected. OpenBuilds CONTROL probably quit or crashed
  2. sharmstr
    Its giving you a link to troubleshoot. I would look take a look at it. Especially section 6.3.1. It could be that since you move the switch that you've shorted it.
  3. Tom Bellfoy
    do you mean it could have shorted out the blackbox ?
    I did check the wiring at the limit switch but could not see a problem
  4. Tom Bellfoy
    I unplugged all wiring to the blackbox still cannot connect, tried everything. looks like the blackbox is dead
    Was power on / usb plugged in while you worked on the switch?
  6. Tom Bellfoy
    Yes i think power was on and usb was defenitely connected
    In that case, it likely did cause a short. Too late to say it now, sorry, but I'll post it here hoping it helps someone after you, never work on wiring and associated components with power on.
    The presence of power means you could have had an incident where the metal pins touched the metal frame / etc while moving it around or fastening it to the frame, shorting V+ to GND. Doing so most likely did cause permanent damage.
    I can try and offer an alternative to a complete BlackBox, if you ask http://support.openbuilds.com/support/home they may be able to sell you just the Brains board.
    Before you contact them though, disconnect the USB cable, turn on power, and just see which LEDs light up - if only the Power LED lights up, the short also damaged the Muscle board, but if all the LEDs light up as normal, you only need a Brains board
  8. Tom Bellfoy
    problem fixed !!!
    Peter was correct, I must have created a short, and my lesson learnt " shut off power when adjusting limit switch positions". The parts dept. sent me a new brain board at no charge which I installed and now its working perfectly.
    Openbuilds have to be commended not only for their speedy replacement via Fedex but also for their no hastle replacement.
    I would like to give a very big thank you to the team at Openbuilds, you guys are the best people to deal with.
    Tom Bellfoy
