Arduino Grbl Laser CNC
Discussion in 'Laser Cutters' started by jpjoshua, May 29, 2018.
  1. jpjoshua
    jpjoshua New
  2. Scotty Orr
    Scotty Orr Journeyman
    Welcome Joshua, and congratulations on the build. I read about your issue. You probably need to adjust the pots (set Vref) on your DRV8825 drivers to get adequate current to cause the steppers to turn. Do a search on "current adjustment drv8825". Here's one link: UPDATE: Current adjustment for motor drivers (DRV8825 / A4988)
  3. jpjoshua
    jpjoshua New
    Thanks, I'll try that next day I work on it!
  4. MaryD
    MaryD OpenBuilds Team
    Hi Joshua. Curious about your plates but from the pic having trouble figuring out what material you used? Are these standard ACRO plate design?
  5. jpjoshua
    jpjoshua New
    Yes they actually are, I'll be updating this post later on today.
    MaryD likes this.
