I am making a custom laser cutter with a build volume of 30"x20". I am using the GRBL 1.1 firmware on an Arduino Uno + CNC Shield with LaserWeb as the software for controlling it.
I used this link here to get the correct screws, nuts, and bolts for my Laser CNC
OpenBuilds ACRO System.
Day 1 (5/28/2018):
I have all the electronics and have installed the firmware on the Arduino. I have mostly assembled the frame but have not yet mounted the electronics such as the laser and the motors.
Day 1 issues:
The motors make a higher tone buzzing and vibrating sound and refuse to spin when told through LaserWeb and/or GRBL Controller. I have tried to reverse the motor connection but the same results have been observed.
Day 2 (5/29/2018):
Today I did a lot of research on how to fix my issue with the motors but lucky for me, the user Scotty Orr posted a solution to my problem. So, I looked at some videos on how to tune stepper motor drivers. I got them all to move using LaserWeb and I couldn't be happier.
Day 2 issues:
I accidentally turned one of the pots on my DRV8825 pots too much and now I can't tune it...whoops! However, I had a spare because I was smart and bought 4.
Day 3 (5/30/2018):
Today was really productive! I got the motors to move even better than yesterday. They sound even more quite today than yesterday and it seems to run very smooth. Tomorrow I plan to start mounting the motors and then to the frame.
Day 3 issues:
None to report.
Day 4 (5/31/2018):
Today I mounted the motors to the mounting planes and to the frame. It's starting to look like an actual laser cutter.
Day 4 issues:
I very quickly realized that I do not have the standoffs for the v-wheels, nor do I have some of the buts and bolts I need to connect some components to the frame correctly.
Day 5 (6/7/18): I have bought more bolts, nuts, washers, and the right size v-wheels to finish mounting everything except the laser module.
Day 5 issues:
I ended up breaking one of the x-axis motor mounting plates, so I made a copy out of a similar thickness of plywood.
Day 6 (6/14/18): Since everything is mounted I decided to add the belts today and check for tension and the smoothness of the movements on the X and Y axis. I also checked for alignment of everything.
Day 6 Issues: Some of the wheels are a little tight so I loosened them and rechecked smoothness.
Day 7 (6/21/18): Today was a big day! I test the movement of the laser cutter using LaserWeb4 and I couldn't be happier because I didn't break anything and it works.
Day 7 Issues: I had some of the motor wires plugged in wrong and it reversed the motor directions. So I changed them to how they needed to be so they move how I want them to move.
Arduino Grbl Laser CNC
Build in 'Laser Cutter Builds' published by jpjoshua, Aug 6, 2018.
Arduino powered Laser CNC using GRBl firmware.
Megamaer, Essam Sultan, gsn713 and 1 other person like this. -
Build Author jpjoshua, Find all builds by jpjoshua
Cutting remote control planes, hotwire cutting guides, laser engraving and laser cutting.Inspired by
Open Builds ACRO System -
