All metal Ox hybrid CNC Router Table
Discussion in 'CNC Mills/Routers' started by Denis Lapratte, Feb 18, 2018.
  1. Denis Lapratte
    Denis Lapratte published a new build:
  2. johnnycnc
    johnnycnc New
    Very anxious to see your build. I am hoping that I can learn from your build.
  3. devloop
    devloop Well-Known
    Heavy Duty outfit, where did you get the rack from? If my belt ever fails me, I would install a rack like this
  4. Denis Lapratte
    You have no idea how strong this table will be, I will never see the end as far as loading capacity!.
    Racks are coming from CNCRouterparts. I made my own Motor mount pivot plate from the DXF file they provide and bought the rest of the kit and racks from them. I will post the VCarve file later for all of the parts I cut with my old CNC.
  5. johnnycnc
    johnnycnc New
    I noticed on your table that you bolted a lot of the joints rather than welded them. Was there a reason for this? I really like this table except when you might have to move it?? :mad::mad:
  6. Denis Lapratte
    Sometimes welding distort meta a bit and it is harder to make it perfectly square. Plus, if welded, it is very difficult to modify, you have to take a new piece of metal. I know this because I made a mistake in the measurement for the Y axis not taking into account the width of the router bracket. The result is that I had to add a few inches to the top 5 supports and the braces were welded to them. Because of that I had to cut them in the middle and weld them. When done, the heat made some of the supports to slightly bend and the result was that I didn't have a perfectly flat surface anymore.
