ACRO question
Discussion in 'CNC Mills/Routers' started by Phillip Frost, Sep 12, 2019.
Tags:
  1. Phillip Frost
    if I purchase the ACRO bundle with all add ons will the machine be complete except for a router? Which router is recommended?
  2. Alex Chambers
    The Acro system is a lightweight system - it is not really suitable for use with a router. What sort of jobs are you planning - this info will help us to advise on a suitable solution.
  3. Phillip Frost
    Mostly cutting out 1/4 to perhaps 1/2 inch plywood shapes with some detail.
    Thanks for your response.
  4. Alex Chambers
    Can I suggest that you have a look at the Openbuilds Lead machine or the Workbee.
    If you are new to cnc then consider the blackbox as a controller - designed especially with beginners in mind.
    Rigidity is important for a machine using a router, so think twice before going above 1000mm x 1000mm. You didn't mention what size parts you plan to cut - if they will be small then there are other options.
  5. Phillip Frost
    I have looked at both of those. They may be budget busters for me. But let’s continue exploring. I so much appreciate your help.
    Generally, whatever I would cut, would would not exceed 30”x24”, much of it being smaller.
    Could you comment on what cutting/carving tool is prescribed or used on the ACRO?
  6. Rick 2.0
    The ACRO is a system designed for use with a laser. You might get away with using a Dremel on the smallest model ACRO but the system lacks a Z-axis and the plates are made of acrylic so they may not handle the stress of a router. Both of these items would need to be addressed and even then you may be underwhelmed with the results. If you're on a limited budget you might consider some variation on the Routy CNC Router (V-Slot Belt & Pinion). The Simple CNC Router (Nema17, V-slot 2040, Arduino, GRBL) also offers some ideas toward a budget solution.
    Alex Chambers and sharmstr like this.
  7. Phillip Frost
  8. sharmstr
    Hey Phillip. Its a build that someone did on their own. Its not a kit you can purchase. If you go back to the link, click on the build tab. The parts list is located in the Files and Drawing tab.
  9. Rick 2.0
    Someone???? :ROFL::ROFL::ROFL:
    It's where this whole party started.;)
  10. sharmstr
    Ah shoot. Sorry. I didnt know. :oops:
    Honestly, I meant it in a more general sense like... "People post builds".
    With that said, I was wondering why there were 23 pages of discussion about it. LOL
    Rick 2.0 likes this.
