5 X 5 Plasma SIMPLE Build
Discussion in 'Laser Cutters' started by devloop, Jan 6, 2018.
  1. devloop
    devloop Well-Known
    devloop published a new build:
  2. Gary Caruso
    Cool build! please upload bigger pics!
  3. mcbuilder22
    How many ton press brake did it take to bend those legs?
  4. devloop
    devloop Well-Known
    The cutting and forming was sourced out locally, they have a large plasma table and Accupress Brake
    mcbuilder22 likes this.
  5. Anthony Bolgar
    Anthony Bolgar Journeyman
    I looked up the stepper/driver combo you picked out for this build, and I must say it is incredibly expensive. You should be able to source out the equivalant setup for about 1/4 of the price.
  6. blackwolf1778
    curious of what it costed to have the frame cut and pressed if you dont mind sharing thanks!
  7. devloop
    devloop Well-Known
    The steel, Cut, Formed, slats & all, $400.00 CAD
    Keith Parker likes this.
  8. devloop
    devloop Well-Known
    Yes, there are cheaper alternatives for electronics, this is my first CNC build therefore I perfer plug and play with support instead of experimenting
    Mike Tanner likes this.
  9. Anthony Bolgar
    I get that, it eliminates potential trouble spots. I guess I just hate paying large sums of money, I would rather have to struggle a bit and save money ;)
  10. devloop
    devloop Well-Known
    Comparing it to purchasing a turn key table ei: Torchmate, Plasmacam, this is still much less money with similar support. When it comes to the digital torch height control, quality components, CandCNC looks like they have it figured out. With the exchange from US to CAD it is the most expensive part of this build, I will experiment with my next CNC project
    Whodare and Moutazhag like this.
  11. devloop
    devloop Well-Known
    180 ton Press Brake used to form the steel parts
  12. Gary Caruso
    That's a great deal on the steel parts, I would have though $1500!
  13. devloop
    devloop Well-Known
    Its a reason I have not bought or built my own CNC table until now, I find the convenience will be worth it, but I can outsource very reasonably here. These guys are not out to gouge, they just want to keep their equipment running
  14. Bigforkg
    Bigforkg New
    Nice table! After 2 year I decided to build one myself. How tall are the legs and the height of the table from the floor? You Z travel? Thats where I stuck on mine. Would you consider sharing the file for the legs only?
  15. devloop
    devloop Well-Known
    Here you go
    • Leg.DXF
      File size:
      23.1 KB
      458
  16. devloop
    devloop Well-Known
    The top of the slats are 30" to bottom of leg, overall leg is 36", used the 40X80X250 C-bean for the Z with jack screw, has plenty of travel, check my files and drawings section for more pics of the Z
  17. Bigforkg
    Bigforkg New
    Thank you very much devloop. This is a big help.
  18. Joe Santarsiero
    Joe Santarsiero OB addict
  19. Bigforkg
    Bigforkg New
    The more I look at your table the more I like it. So it belt drive, did you come up with the X and Y axis gantry plates? I dont see anything like that at openbuilds.
  20. devloop
    devloop Well-Known
    Yes it will be belt drive, I'll post more pics as soon as I get the electronics this week. Designed the plates, outsourced water-jet cut 5052 Alum.
  21. Bigforkg
    Bigforkg New
    I was afraid you say that. Would you be willing to share those files?
  22. devloop
    devloop Well-Known
    Here it is
    Alfonso Noriega likes this.
  23. Bigforkg
    Bigforkg New
    Thanks a million! Cant wait to get going now. Hopefully mine will look half as good as yours.
  24. devloop
    devloop Well-Known
    Post some pics when you get it going
  25. Bigforkg
    Bigforkg New
  26. Michael.M
    Michael.M Veteran
    Nice work! I really like the Heavy Equipment Yellow
  27. devloop
    devloop Well-Known
    Thanks, brother has a business making front end loader blades, he threw in the parts with a batch he was painting
  28. pschoggens
    My first thought it to say......Well go on then...show us the rest of your files :)
    You do have a really nice looking table! I have no experience with CNC plasma as I have just hand held everything. I recently inherited a nice plasma machine and am thinking to build a table for the ability to make nicer cuts. I do this as a hobby, but like to build things right the first time. I started my thought process as a 16" x 30" to sit atop a utility cart, but as I progress with my education on the subject, I realize that was way too small to be practical and now feel it would at least do a 2'x4' sheet to make material handling easer. What are your thoughts on size? Also I seemed to have skimmed over belt drive. Someone who has accomplished such a nice build must have good reason for choosing belt drive over screw. Would you please share your thoughts?
    Powell
  29. devloop
    devloop Well-Known
    Belt drive offers simple, smooth, fast, & accurate motion. My gantry is light weight therefore this system should be fine
  30. Denis Lapratte
    Super cool, I like the looking of the frame and legs done by pressing. And the color also add to the great looking.
    You mentioned the pressing was done by a local company; where are they located? I'm also from Canada and would like to see if they are close by.
    I have same problem when buying in the USA, costs are at least 30% considering the rate exchange and the cost of the shipping.
    I'm in the process of building a CNC and I was thinking to register for the contest, but after looking at your project and a few others, I don't think I have a chance! :).
    I'll keep looking at your project as I plan to upgrade my CNC with plasma capability later on and I will see how you do and probably grabs a few ideas.
    Best of luck to complete your project.
