2000mm long 8mm lead screws?
Discussion in 'CNC Mills/Routers' started by CKerv, Dec 23, 2020.
  1. CKerv
    CKerv New
    Anyone know where I can buy 2000mm long 8mm lead screws? I'm planning to buy 2ea. 1500mm from OpenBuilds, but that seems to be the longest size offered.
  2. sharmstr
  3. CKerv
    CKerv New
    Thanks! Looks like it. Although, have you used these before with OpenBuild parts (anti-backlash nut)? Open Builds says "Lead Screw Diameter: 7.8~(mm) Note - These lead screws have been customized to work directly with OpenBuilds system"
  4. sharmstr
    No. Just found the link by searching this forum :)
  5. jeffmorris
    jeffmorris Journeyman
    I don't know why OpenBuilds sell lead screws that are 7.8mm in diameter instead of lead screws that are 8mm. I had to make a tap out of a small piece of lead screw to enlarge the tapped holes in nut blocks that came from OpenBuilds.
  6. CKerv
    CKerv New
    Hum. Tapping nut blocks does not sound like something I want to do :) I guess I'll keep looking.
  7. ljvb
    ljvb Well-Known
    That is way too long.. the screw will seriously deflect all over the place at that length.. if you want to go to 2m.. you really should be looking at rack and pinion drive.
  8. Brett Sutherland
  9. CKerv
    CKerv New
    Will the screw deflection actually be a problem though? Sure, it sags a little between the nut block and the end of the screw, but is that actually going to cause unwanted movement along the rail? I plan on using a tensioning system and thrust bearings.
    Brett, you have a lot of experience using that plastic nut block? I plan on using this a lot, worried about the plastic.
  10. ljvb
    ljvb Well-Known
    Yes, it will.. you have a slightly sagging screw.. add rotational motion.. it's going to cause vibrations and will affect accuracy.. you will basically have a steel jump rope in your c beams... (okay, probably not that bad.. but bad enough)
  11. CKerv
    CKerv New
    Bummer. Is aftermarket rack and pinion available. Doesn't look like open builds offers it.
  12. ljvb
    ljvb Well-Known
    Yes, you will have to go aftermarket. Either rack and pinion (best option), or belt driven. See the builds here, there are a few 4x8 custom builds using both options.
  13. JustinTime
    JustinTime Veteran
    You could also use two belts that will act as rack & pinion. If you do, use a big belt, like an G3 rather than a G2.
    #14 JustinTime, Dec 25, 2020
  14. Brett Sutherland
    Am using them on modified OX 1510 seem to be very stable.
    #15 Brett Sutherland, Dec 25, 2020
  15. CKerv
    CKerv New
    I'm looking to get away from belts. I've been having issues with them stretching.
  16. Giarc
    As @JustinTime mentioned, a double belted system will help avoid stretching. It is sort of like a rack and pinion. Many Ox CNC machines were built this way bag in olden times (4-5 years ago). If you search "double belt" on the forums here you will find many examples to include one that had a 3000mm Y axis.
  17. CKerv
    CKerv New
    Giarc, what is your thought on the 2000mm lead screw. You think the sag will cause problems? Even with the tensioning?
  18. JustinTime
    JustinTime Veteran
    I think that unless you tension it really really well, which will require quite a beef-up at the point of tension, you'll get whipping from the long screw. As Giarc said, the double belt has no stretching and is much simpler to install and more cost effective and you can have high speeds with no whipping.
  19. Peter Van Der Walt
    Remember every force has an opposing force. By the time you have enough tension on a 2m screw to avoid whipping, you are also pulling the C-beam into a Bow :)
  20. Rick 2.0
    A couple of resources you might look into include:
    Eliminating Lead Screw Whip on the Workbee CNC Router | OpenBuilds Won't be much help on solving the whip on a screw of the length you seek but will give you a better idea of what you're dealing with.
    And not the best example out there but I was unable to locate the previous discussion here on the forum. The basic concept is reducing the unbraced length of the screw by using a free floating shuttle system.
  21. Giarc
    As mentioned by the others, an 8mm x 2000mm leadscrew is not ideal. I used a 1/2 inch 5-start precision lead screw for my 1500mm Y axis and have no whipping issues. If I were building a 2000mm long machine, I would look at rack and pinion.
  22. JustinTime
    JustinTime Veteran
    My 1500mm lead screws have quite a whip, at high speed. They are 16mm thick but are not tensioned since they came without thrust bearings. I may upgrade in the future to thrust bearings.
