1250x1000 Build
Discussion in 'Laser Cutters' started by jnsbanman, Jan 9, 2020.
  1. jnsbanman
    jnsbanman Well-Known
    jnsbanman published a new build:
  2. jnsbanman
    Got the bed frame made and the knife bed installed today. Still waiting on interior panels to be cut so I can start mounting electronics.
  3. jnsbanman
    Here is some more of my progress from this weekend.
    - Interior panels on
    - Wiring run to the steppers and end stops
    - Drivers, controller and power supply added
    I should have some motion test this week I hope.
  4. Jaybyrd42
    Jaybyrd42 New
    Loving the build! I'm in the process of sourcing parts for my build but I'm having trouble finding a bed large enough (1500x1500), where did you order yours from?
  5. jnsbanman
    Check out Will Feng Store on AliExpress. He can custom size one for you. Very reasonable pricing too. Tell him Jason Banman sent you
    Jaybyrd42 likes this.
  6. jnsbanman
    First Moves... check tube and tube power supply next up.
  7. James Babcock
    Is this a cloudray linear actuator setup?
  8. James Babcock
    I would like to know where you sourced your knife bed parts from? If you don't mind sharing.
    Jim.
  9. jnsbanman
    Go to Will Feng Store on AliExpress... Tell him Jason Banman sent you
  10. jnsbanman
    Got the water system running yesterday, hope to get the air assist running today and get a test burn in. Wait on exterior panels to be cut, and still have to build the lid.
  11. James Babcock
    Thanks for the info. I does not look like they offer them directly. Can I assume you had to contact them? I see that the linear actuator kits from Feng and Cloudray are virtually identical. Looks like Will Feng is cheaper though. I wonder who is actually making them. My setup is stuck on hold until China gets moving again.
    Jim.
  12. jnsbanman
    Yes I have had him make that bed custom, he is making me a custom laser tube as well. He custom sized my X/Y stage as well. He is responsive on chat, and has fairly good english
