1/2 inch collet spindle for ox cnc (110v)
Discussion in 'CNC Mills/Routers' started by DarkPenguin, Oct 18, 2018.
  1. DarkPenguin
    DarkPenguin Well-Known
    Any suggestions?
    My current setup is a 500w spindle from aliexpress. For what I do it seems okay but I take tiny bites with it and its chuck is an er-16 which doesn't do 1/2" collets.
    From what I can tell it looks like the Hitachi M12VC is the way to go. Light enough, powerful enough and supports 1/4" and 1/2" collets. And it runs on 110v.
  2. Kevon Ritter
    Kevon Ritter Veteran
    What are you doing with it? No machine on these boards can effectively use a 1/2" without underloading/overheating it. Anything spindle big enough to turn it will also more than likely be too heavy. 3/8" is pushing the hobby end. 1/2" starts venturing into machine shops.
  3. Rick 2.0
    MaryD likes this.
  4. DarkPenguin
    Mostly working with hard woods. There are a handful of bits that I can only find in 1/2" shanks I'd like to use for leveling. Slow going and very shallow cuts.
  5. DarkPenguin
    Thanks for the link to the build!
